Op Amp Gain
smudge
:D Hi
I am new to Op Amps so could anybody help me with a question regarding this please.
I need to create a circuit wherethe output is ten times the difference between its two input signals. I think this could be realised using just two operational amplifiers and five resistors.
could anybody help please??? :lol:
Only one opamp is required, and four resistors.
Like so:
Sorry I forgot to mention the equation I would like to base my circuit around.
Vo=10(V2-V1)
Would a second op amp be required to get rid of the -
Yes, you could use an inverting amplifier, with a gain of -1, on the output of the above circuit.
Or you could just swap the inputs.
I have used the search engines to find information regarding OP AMPS and indeed the example given above is used in many instances. However, the question I have requires me to find any information I can to obtain the same results using 2 Op Amps & 5 Resistors. I would also like to find any relevant equations to find the resistor values. This is proving rather difficult, I have been on many sites!!!
