Old Zenith TV set
jralegriam
Old Zenith TV SAR2153BT7, with horizontal line (vertical scan off), was changed Vert Out IC, problem continue, was checked all related components, are Ok. Some suggestion for to check?
First thing your new Vertical I.C needs power to/on it to be able to work. Google the Vertical I.C number and then check with a multimeter to see if it has supply voltage on said pins.
First step.
Cheers
/timewarp on
It will be the PCL85
/timewarp off
oops! where did the last 40 years go?
