Old Distortion Analyzer and Audio Analzyer
walters said:
"Push-pull transistors alternate during the waveform. One transistor conducts current when the waveform goes upward, then the other transistor conducts current when the waveform goes downward. "
Using a Single Transistor in normal mode "conducts" current upward and downward whats the difference between Pull-pull VS normal mode?
Because they both "conduct" upward and downard waveforms
A single transistor is non-linear therefore amplifies the top of the waveform a different amount from the bottom of the waveform.
Push-pull transistors amplify their half of the waveform the same amount.
This is a copy-and-pasted sim of push-pull transistors. Each transistor compresses its half of the waveform a little but by the same amount:
This is a sim of one transistor incorrectly biased so that it clips the waveform's bottom. The other pic shows its output when it is correctly biased and with a little amount of negative feedback to make it even better:
Thanks alot of the pictures and help
So the "one" transistor has different compression than the push pull mode?
The "one" transistor baised correctly still "conducts" both ways and looks the same as the Push pull mode whats the difference?
From looking at the oscilloscope pictures how can u tell the even and odd harmonic percentages?
If the waveform is clipped on the lower or upper then u say the even harmonics is 40%
In the oscilloscope sim picks where is the 2nd harmonic distortion?
i still can't see it or know where its at
Not really, the single transistor just is DC-offset since it has no means to go negative it must sit on an offset to produce a sinewave, AC-couple will remove the offset tho
Yes. The single transistor compresses the top of the waveform when it is nearly cutoff. Each transistor of a push-pull type compresses the waveform when it conducts the most.
The "one" transistor biased correctly still "conducts" both ways and looks the same as the Push pull mode whats the difference?
I can see compression of the top half of the single transistor's waveform. It isn't much because the emitter resistor adds a little amount of negative feedback to reduce its distortion.
Experience at looking at waveforms on a 'scope and comparing the compression seen with the actual amount of distortion measured on a distortion analyser. I can see 5% even or odd harmonics distortion on the compressed sinewaves on a 'scope. I can hear about 0.1%.
No. If the waveform has asymmetrical clipping then it has even harmonics distortion. The amount of clipping determines the percentage of distortion.
Think about it. You can have an undistorted waveform with only 0.0001% distortion then cause it to clip slightly. The distortion won't suddenly jump to 40%, it might be only 0.1% or less, or more. 40% distortion would be caused by very much clipping and sound horrible (unless you like fuzz).
Thanks guys alot for the help on this
"asymmetrical clipping then it has even harmonics distortion"
so Asymmetrical clipping= Even harmonics distortion
Symmetrical clipping= Odd harmonic distortion
2nd harmonic distortion= ?
"The amount of clipping determines the percentage of distortion."
How do i measure the Clipping?
How do i measure the Percentage of distortion?
Weren't you listening? Aren't 2, 4, 6, 8 even numbers?
Usually if there is 2nd harmonic distortion then the other even harmonics are also present.
Many good amplifiers have a clipping indicator. A 'scope shows clipping.
You don't measure clipping, you avoid it (unless you like fuzz).
On a distortion analyser.
Yes but what does the 2,4,6,8 look like on a oscillscope please?
Yes but i don't even know what 2,4,6,8 even look like how do i tell what 2 looks like from 4,6,8 how do i seperate them?
Does the distortion analyer does it automatic for u ?
How do u use the distortion analyer to measure the percentage of distortion any skills or knowlegde ?
walters said:
what does the 2,4,6,8 look like on a oscillscope?
I answered this and showed pics of the compression of the upper or lower part of a sinewave.
There is not a reason to separate them.
Very expensive ones do.
It is easy after reading its operating instructions.
walters said:
So the compression creates even or odd harmonics?
Yes. Even, odd or both depending on the circuit.
Whats the difference between Clipping VS compression?
Clipping caused distortion occurs suddenly when the signal input of an amplifier exceeds the level when the output runs out of supply voltage.
Compression caused distortion is always present and is worse at the waveform's peaks.
When are you going to ask about crossover distortion, ordinary intermodulation distortion or Transient Intermodulation Distortion? :lol: :lol:
