Obtaining a desired Impedence
windozeuser
I need to select components in multisim that will give an impedance of (3 + j4)
Now to calculate inductive reactance the forumula is XL = 2(pi)FL
I need to calculate the inductance value for the needed impedance so...
j4/(2(pi)60) = inductance needed?
I am connecting this to a 60Hz AC source, I wouldn't use (3 + j4) , just j4 right in the calculation? the 3 is a real part which is a 3 ohm resistor?
You can put a 10.6 mH coil in series with 3 ohm resistor.
Or put 16.6 mH coil in parallel with 8.33 ohm resistor.
Both equal 3 + j4 at 60 Hz.
