negative supply
t.man
how can one make a negative voltage supply? would interchanging the wires of, say a 12V adapater, suffice?
hi t,
Buy a mains 12V dc plug adaptor and you can use it either has a +12V or -12V supply, connect the +V lead to your circuit 0V/common and the other lead is the -V12.
hi t,
i dont know if i get you. are u saying i should connect ,what i normally use as +12V lead, to 0V/GND . because when i use multimeter i can see when i interchange leads i measure negative voltage.
If you use separate 12Vdc psu adaptor, connect the +12V lead to 0V ground and the other lead is -12V.
Think of it like a 12V battery, you can connect those either way around to give a +V or -V with respect to 0V.:)
OK.?
OK.?
I can not use the same psu adapter to provide both +V and -V?
You Can'not use same adaptor for both + & - 12V. If You want +12v & - 12 v in single Adaptor then go for 24 volt Adaptor (transformer) and use regulator 7812 & 7912 with filter 1000mfd Capacitor.
hi t,
As already pointed out, its not possible to use a single 12Vdc adaptor for both the +12V and -12Vdc.
Exactly what are you trying to do with these supplies.?
it is for this amplifier circuit. it uses LF442-CN. so i can see it'll require +15V and -15V. am i right?
if yes, how can i supply these voltages?
Are you amplifying ac or dc signals, and ver what range of input/output voltages.?
Do you have a circuit diagram.?
i think its dc. im not sure of input signals but output runs from 0 to about 2.5V or something like that
hi t,
The input pin3 is grounded, but you have a 10K going to 15V on pin3.? also a 10uF.?
You could consider using a 7660 -Voltage generator ic, running from the +V rail to give a negative voltage.
There are more modern/better devices than the 7660, but it will give you an idea.
If an output voltage of close to 0V to say +2.5Vdc is OK, it would be possible to use a OPA that will work from a single supply.
EDIT:
You could build one of these 555's
hi t,
EDIT:
use this as -V supply?
You could buy an adaptor with 12VAC output and use a diode voltage doubler to get a positive and negative supply.
hi t,
EDIT:
which 555? LM or NE?
hi t,
I would use a TTL version, IIRC they can output about 200mA.
EDIT: added a data extract.
hi, i want to check the items at the store, what values are the caps? i.e is it 220uF and 0.05uF?
They are 220µF at 16Vwkg[min] Electrolytic and a 0.05µF ceramic, a 0.047µF would be OK.
Any of the 1N400x diodes will be OK.
