Negative power regulators? why?
  • Thread starter Thread starter Souper man
  • Start date Start date
S
Souper man
Guest
I ordered some parts from electronic goldmine, and one of the items was a semiconductor grab bag. It came with 50 brand new components, including V-regs, transistors, MOSFETs, and some logic chips. One of the v-regulators is a 7906. It supplies -6v at 1 amp. What is the point of a negative regulator? Is it like a - side of a battery? How could I use this?
Oh, what other uses could I use this for? Is this like the negative side of a battery?
Negative side of a single battery is consider ground. If you have 2 batteries in series, +ve side is the +ve supply, -ve side is the -ve supply and their joint is the ground.
If you want to get -ve supply from a battery, say 9 V battery. It can supply +-4.5 V whereas you can use voltage devider to make 4.5 V from 9 V, and take that point as ground reference.
audioguru has very nice diagram for the single supply of op-amp.
Not exactly, think of it as two 12 volt batteries where you connect the negative terminal of #1 battery to the positive terminal of #2 battery and this connection is also brought out to become the circuit common. Now measuring from this circuit common you will read +12 from the #1 battery positive terminal and and also -12 from the #2 batteries negative terminal. This will make sense when you understand that if you measure, in this set-up, from #1 battery positive to #2 battery negative you will see 24 volts total.
Clear? In a circuit that requires both a positive and negative regulated voltages (relative to circuit common), the positive and negative regulators will perform the same function as the two batteries in the example above.
Lefty
