Need to heat an IC...will my solution work?
Ron H said:
I picked 20 ohms for 0.5 watt dissipation. The resistor will have 3.3v-Vce(sat), or about 3.1v across it.
R=V^2/P
R=3.1^2/0.5
R~20
There is nothing magic about 0.5w, it's just the target I've been shooting at. 62 ohms might work. You'll get about 160mw, which might be enough to heat your chip.
Got it. Thanks.
Ron H said:
How weird. Did you notice in your post, where you quoted me, it said 160 ohms? That was the value I had given when I thought you were using 9 volts. Maybe I edited it, but there is no indication on my post that I did. Oh well.
Actually, I did notice that. I just figured that while I was working on the post, you had edited your post. I find that some forum software doesn't always add the "Edited..." until some event happens. Either a certain amount of time passes, or the member logs off, or another member reads the post...I don't really know. I just know that if you edit your post quickly after posting it, you don't get the "Edited..." line.
Anyway, I'll start gathering the parts I need for this. Once again, I appreciate all the help.
Graystar said:
Nigel Goodwin said:
With Ron’s latest update, the base-emitter current is controlled by a 1.3k resistor and the 3.3V power supply. That gives an Ibe of 2mA (I think.) With an hFE somewhere around 50-75 (according to the sheet,) that should give an Ice somewhere around 125mA.
Going back to what you were saying about needing limiting, I thought that the 2mA current was what provided that limiting. Are you saying that I need something else to limit current? That there’s a problem if the voltage from the battery is dropped occurs across the transistor?
Sorry about the slow reply, I've been to bed :lol:
The base current doesn't provide any collector current 'limiting' at all, and transistors exhibit 'thermal runaway' as I mentioned previously. This is because the transistor is temperature sensitive, the more current it passes the hotter it gets (which is what you were looking for), BUT the hotter it gets the more current it passes (which is what you don't want). This will continue, passing more and more current, and getting hotter and hotter, until the device fails (which could occur in a very short space of time) - it's essential to have some kind of current limiting in the circuit, a simple resistor will do this, and become the heating element itself.
Okay, I understand now. I've already added the resistor into the circuit to be used as the heating element. Now I just have to find those resistors someplace!
Thanks!
This is intended to be ran inside a pc is it not? Why are you using a 3.3V regulator and a battery? Just use the 5V power from the PC. (There's nothing in the datasheet that says 5V reduces accuracy)...
Just a note, if you think this heating setup is going to keep your ic at 85°C you're in for a little surprise :roll:
This board will sit next to a PC motherboard that has been specifically setup for testing water-cooling solutions. It will not be permanently attached.
I’m using a separate battery because the first sensor circuit I made exhibited strange and irresolvable behavior that appeared to be related to grounding, so I wanted an isolated power system for the sensor.
I’m using 3.3V because that’s what’s specified as the conditions required for +/-0.8C accuracy. There is a parameter called “Supply Sensitivity of Temperature” that’s given as +/- 0.2 C/V. Seeing that voltage can affect temperature, I figured I’ll just stick with the specs.
Why is that?
I was looking at the circuit and I was wondering...
Since I'm using a battery for power, shouldn't I be able to remove both 0.1uF caps and the 200 Ohm resistor without ill effects? Those are for noise reduction, which I'd think I shouldn't need in this particular setup. The output from the 1658 seems clean enough to not cause any problems, and there's still the 10uF cap across the output supply.
SHDN is just a logic level. Since I have no shutdown circuitry, I can just connect SHDN directly to Vin, right?
Thanks.
Since I'm using a battery for power, shouldn't I be able to remove both 0.1uF caps and the 200 ohm resistor without ill effects? Those are for noise reduction, which I'd think I shouldn't need in this particular setup. The output from the 1658 seems clean enough to not cause any problems, and there's still the 10uF cap across the output supply.
The 0.1uF's provide a low impedance path across the supply, and the 200 ohm forms part of a low-pass filter - I wouldn't suggest leaving them out. A battery supply needs decoupling capacitors just as much as a mains supply.
Should be fine!.
Follow-up...
The circuit hasn’t worked yet.
First, the 9V batteries were dieing quickly, so I started using a large 12V battery instead. I used a 10 Ohm Vishay metal-film resistor as the heater because it has a heatsink mount and proper power rating. However the temperature sensor only reached 67C with it. Also, the 1.3k Ohm resistor was way too large to get enough current to flow and was eventually reduced to 270 ohms.
The last thing I tried was, essentially, my original idea except using the PN2222A instead of a JFET. That worked in getting the IC up to 85C (was able to go over 90C.) However, something was preventing the OVERT signal from working properly. Sometimes the circuit would turn off the transistor, sometimes it wouldn’t. So the temp would go up, down, up, and then either just keep going up, or go down and never come up again. The behavior was random. I think it has something to do with the amount of current I was forcing through the OVERT pin.
I think the next thing to try is to use the OVERT signal to turn on a PN2222A that is controlling a second PN2222A to heat the sensor. I should be able to greatly reduce the current flow through OVERT that way.
Another option is to use the unregulated input voltage for the transistor-resistor heating circuit. If the resistor was able to heat the IC to 67C on 3.3V, it will definitely go to 85C on 12V.
