need hitech config help
anoopmb25
hi sir,
am using pic18f2550 for a 10 x 5 matrix project but i dont know how to configure it as
internal oscillator 8mhz ra6 as i/o port
1:16 prescaler
16 bit mode pls help me my code is below is it correct i dont nedd usb and other such things
using below code interrupt not working
__CONFIG(1, IESODIS & FCMDIS & INTIO);
// Config word 2
__CONFIG(2, VREGEN & PWRTEN & BORDIS & WDTDIS);
// Config word 3
__CONFIG(3, PBDIGITAL & LPT1DIS & MCLREN);
// Config word 4
__CONFIG(4, XINSTDIS & STVRDIS & LVPDIS & ICPORTDIS & DEBUGEN);
// Config word 5, 6 and 7 (protection configuration)
__CONFIG(5, UNPROTECT);
__CONFIG(6, UNPROTECT);
__CONFIG(7, UNPROTECT);
main
void main(void)
OSCCON=0x70;
T0CON=0x83;
TMR0H=0xFF;
TMR0L=0xF6;
INTCON=0;
INTCON2=0;
INTCON3=0;
PIR1=0;
PIR2=0;
PIE1=0;
PIE2=0;
IPR1=0;
IPR2=0;
IPEN=0;
ADCON0=0;
ADCON1=0x0f;
ADCON2=0;
T1CON=0;
T2CON=0;
T3CON=0;
SSPCON1=0;
SSPCON2=0;
RCSTA=0;
TRISA=0b00000111;
TRISC=0b10000000;
TRISB=0;
PORTA = 0b00000000;
PORTB = 0b00000000;
PORTC = 0b00000000;
CCP1CON=0,
CCP2CON=0;
SPBRG=51;
TXSTA=0x22;
RCSTA=0x90;
BAUDCON=0x48;
SPBRGH=0;
POR=1;
//displayClear();
IPEN=1;
GIEH = 1;
GIEL = 1;
//INTCONbits.PEIE = 1;
TMR0IE = 1;
//displayPlot(2,3,ON);
	while(1)
COL_0=1;
COL_1=1;
COL_3=1;
 ROW_0=1;
ROW_1=1;
 ROW_2=1;
ROW_3=1;
 ROW_4=1;
interupt
void interrupt low_priority lpHandler(void)
	unsigned char rowCounter;
	// Is this timer0 interrupting?
	if (TMR0IF)
COL_0=1;
COL_1=1;
COL_3=1;
 ROW_0=1;
ROW_1=1;
 ROW_2=1;
ROW_3=1;
 ROW_4=1;
		TMR0L = 0xF6;	// Reset the timer0 counter
		TMR0IF = 0;	// Clear the timer0 interrupt flag
please help me
You forgot to set the correct System Clock Select Bits <OSCCON 1:0> to select the internal oscillator block as the system clock. Try changing "OSCCON=0x70" to "OSCCON=0x72".
OSCCON=0x70 in this mode its working fine in mplab c18 compiler
when using OSCCON=0x72 interrupt not working but main function started working
thanx
When you say "it's working fine" are you saying that the internal oscillator is working as an 8MHz oscillator? Also, did you even try "OSCCON=0x72"?
means when i set all rows and columns ON in main function(in while(1) its working
but when i set all rows and columns ON in interupt routine its not working
thanx
ya its working as 8mhz oscillator in mplab c18 compiler i changed to hitech compiler becoz asccii table storage problem in mplab c18 compiler
wat wil be the problem pls help me
This is one off these time when both work there only 3 bits that set for 8 mhz IRCF2:IRCF0: which can be 0x70 or 0x72
or any combination that set IRCF2:IRCF0 to 111 But that don't mean they will turn on the oscillator 0x70 and 0x72 will turn on
at full speed but if you set this wrong 1: Depends on the state of the IESO Configuration bit. 0x70 will not work
So to use 0x70 this has to set IESO Configuration bit 0 = Oscillator Switchover mode disabled in your config
The old saying there more then one way to skin a cat there is LOL
This is one off them LOL
I don't like Hi-tech to much It changes to much with each update
Here a little Hi-tech sample to look over
void init(void)
	T1CON=0x80;	/* we are testing  TIMER1 */
	T1CKPS1=RA1;/*update values of prescalar bits*/
	T1CKPS0=RA0;
	TMR1IF=0;/* Clear overflow flag*/
	TMR1IE=1;/* Enable TIMER1 interrupts */
	TMR1=0;/*Load initial value to TIMER1*/
	T3CON=0x00;/*use TIMER3 as reference for comparison*/
	TMR3IF=0;
	TMR3IE=1;
	TMR3=0;	/*Load initial value to TIMER3*/
	RBIE=1;	/* enable PORTB interrupts to */
	GIEH=1;	/* allow interrupts from PUSH BUTTONS */
	GIEL=1;
	TXEN=1;/* enable serial port transmissions */
	SPEN=1;
	TXIE=0;	/* not interrupt driven */
	TRISA=0x03;	/* Set first 2 bits to input to read DIP switch values */
	ADCON1=0x0F;/*configure pins of PORTA to be digital inputs*/
	TRISB=0xF0;/* Push button is connected to   RB4 to turn timers ON and OFF*/
	TRISC=0x01;/* 1bit LED panel is connected to RC1 to indicate TIMER1 ON/OFF status*/
			/* Push button connected to  RC0 is used to test TIMER1 as a counter*/
	TRISH=0x00;/* LED panel indicates frequency of TIMER3*/
	TRISE=0x00;/* LED panel indicates current frequency of TIMER1 */
	TRISF=0x00;/* LED panel shows current value of register TMR1L */
	TRISD=0xFF;/* 8-bit DIP switch to set  value of LED pannels */
	LED1=PORTD;	/*Load LEDs with current value of 8-bit DIP*/
	LED2=PORTD;
	LED3=TMR1L;	/*Load LED3 with  current value of TMR1L*/
	UPDATE_REQUIRED=1;
This is for timer0
void init(void)
	T0CON=0x4E;
	TMR0IF=0;			/* Clear overflow flag*/
	TMR0IE=1;			/* Enable TIMER0 interrupts */
	T0PS2=RA2;
	T0PS1=RA1;			/*update values of prescalar bits*/
	T0PS0=RA0;
	T1CON=0x80;			/*use TIMER1 as a reference for comparison*/
	TMR1IF=0;
	TMR1IE=1;
	GIEL=1;
	TXEN=1;				/* enable serial port transmissions */
	SPEN=1;
	TRISA=0x17;			/* Set first 3 bits to input to read DIP switch values and*/
					/*4th bit for counter, clock input */
	ADCON1=0x0F;			/*Configure all ADC pins  to be digital inputs*/
	TRISB=0xF0;			/* Pushbutton switches to change TIMER0 status are on PORTB */
	TRISC=0xBF;			/* LED panel to indicate oveflows of TIMER0*/
	TRISH=0x00;			/* LED panel to indicate oveflows  of TIMER1*/
	TRISD=0x00;			/* 8-bit DIP switch to set  value of LED pannels */
	TRISF=0x00;			/* LED panel to indicate current  value of TIMER0*/
	TRISE=0xC0;			/* LED panels to indicate current mode of the TIMER0*/
	TMR0=1;				/*Load initial value to TIMER0*/
	LED1=DIP1;			/*Load LEDs with current value of 8-bit DIP*/
	LED2=DIP1;
	LED3=TMR0L;			/*Load LED3 with current value of TMR0L*/
	UPDATE_REQUIRED=1;
If you would Like tell what your trying to do would help?
You can scan your led's without using the timer0 Nigel has a 64 led board
Your just wanting 50 which would work with a little changes to hardware and coded in C
You can use the timer0 to fire your led's on time and scan your led's. But it's hard to see what your trying to do here
no schematic
I would lay out a plan
This uses simple loop for timing
This one to show a pic can light some leds the boards Nigels idea no divers just fast scaning and the Pic never reached 80ma
i am trying to make break light system for my bike
i made a 10 x 5 led matrix display using pic18f2550 and 10 bc548 transistor for 10 columns (negative supply) and 5 bc548 and 5 bc557 coupling for 5 rows(positive supply). positive supply is from a lm317 ic its the basic hardware
pic is configured as 16 bit internal oscillator using 1:16 prescaler for better row scanning
actually i made this project for my bike and it is interupt driven and wish to control the brightness via pwm
Say for example,
total 3 interrupts
one for breaklight and other two for turning indicator
when the circuit is powered it is in park light mode that is all leds on with less brightness
on default no power supply given to circuit and working is given as follows
when park switch is on only power supply goes to circuit without any interrupts and it is in low brightness mode
on break signal power supply and respective interrupt is gone to circuit and same for turning signal
but the timer0 interupt not working
pls help me to blink an led using these config then i can do rest
I see now a little better You don't need interrupt to scan stop, right, left, park. I would use it for led on time park 50% bright
stop, left, right, full bright I try to post you something after collage classes I'm finishing it after 30 years LOL but then I can could say I'm a EE lol.
There a errata for the 18f2550 and Hi-tech I tried the same code just changed to swordfish and timer0 works fine use the same setting in Hi-tech and it will not come on.
You put these in one folder first one you can name what ever you want like main.bas the last one has be saved as timer0.bas
This is just a sample showing how to set up timer0 and count out on PORTB with some leds
Device = 18F2550
Clock = 8
Config FOSC= INTOSCIO_EC
Include "timer0.bas"
Include "utils.bas"
Dim LEDS As PORTB
Event LEDFlash()
      LEDS=LEDS +1
End Event
Interrupt ISR()
     INTCON.7=0
     If Timer0.InterruptFlag =1 Then
        Timer0.SInterrupt()
     EndIf
     INTCON.7=1
End Interrupt
// main
Utils.SetAllDigital()
OSCCON = $72
ADCON1 = %00001111
TRISB = %00000000
PORTB = %00000000
Timer0.Initialize(LEDFlash)
Timer0.SetPrescaler(Timer0.PS2)
Timer0.EightBit = 0
Timer0.Preload=1000
Timer0.EnableInterrupt()
Timer0.Enabled()
Enable(ISR)
While true
Wend
timer0.bas
Module Timer0
Type TEvent = Event()
Public Const
      SRCInternal = 0,
      SRCPIn = 1,
      EDGEFalling = 1,
      EDGERising = 0,
      PSDisabled = 1,
      PSEnabled = 0,
      PS256=7,
      PS128=6,
      PS64=5,
      PS32=4,
      PS16=3,
      PS8=2,
      PS4=1,
      PS2=0
Dim FPreload As Word,
    FPrescaler As Byte,
    FEnabled As T0CON.7,
    FInterrupt As INTCON.5,
    OnISR As TEvent
Public Dim
       Preload As FPreload,
       EightBit As T0CON.6,
       Source As T0CON.5,
       Edge As T0CON.4,
       PrescalerEnabled As T0CON.3,
       InterruptFlag As INTCON.2
Public Sub Enabled()
       TMR0L = FPreload
       FEnabled=1
End Sub
Public Sub Disabled()
       FEnabled=0
End Sub
Public Sub EnableInterrupt()
       FInterrupt=1
End Sub
Public Sub DisableInterrupt()
       FInterrupt=0
End Sub
Public Sub ClearInterrupt()
       InterruptFlag=0
End Sub
Public Sub SInterrupt()
       OnISR()
       TMR0L = FPreload.Byte0
       TMR0H = FPreload.Byte1
       ClearInterrupt()
End Sub
Public Sub SetPrescaler(ByVal pPrescaler As Byte)
       Select pPrescaler
              Case PS2
                   FPrescaler = PS2
                   PrescalerEnabled=PSEnabled
              Case PS4
                   FPrescaler = PS4
              Case PS8
                   FPrescaler = PS8
              Case PS16
                   FPrescaler = PS16
              Case PS32
                   FPrescaler = PS32
              Case PS64
                   FPrescaler = PS64
              Case PS128
                   FPrescaler = PS128
              Case PS256
                   FPrescaler = PS256
              Else
                   PrescalerEnabled=PSDisabled
       End Select
       T0CON.0=FPrescaler.0
       T0CON.1=FPrescaler.1
       T0CON.2=FPrescaler.2
End Sub
Public Sub Initialize(pEvent As TEvent = 0)
       Disabled()
       EightBit = 1
       Source = SRCInternal
       PrescalerEnabled = PSDisabled
       DisableInterrupt()
       OnISR = pEvent
End Sub
Here a little sch to start with I need to see your led hookup. anode + and cathnode-
