need help with PWM,Interrupt and Timer0 coding in C language on PIC18F
twiart
I want to produce a frequency(I use PWM) for a certain period of time(timer0),then interrupt-on-overflow to stop the frequency for another period of time.So i should have tones play at certain interval.Below is my attempt on coding for that purpose and it isn't working...Please help me find where has gone wrong.Thanks !
/** I N C L U D E S **************************************************/
#include "p18f46k20.h"
#include "delays.h"
#include "12 CCP PWM.h"  // header file
#include "08 Interrupts.h"
/** V A R I A B L E S *************************************************/
#pragma udata   // declare statically allocated initialized variables
/** D E C L A R A T I O N S *******************************************/
void timer0(void);
#pragma code    								// declare executable instructions
void main (void)
	// set internal oscillator to 1MHz
 	//OSCCON = 0b10110110;          		  // IRCFx = 101
 	//OSCTUNEbits.PLLEN = 0;                //PLL disabled
//PWM settings for a frequency
	TRISDbits.TRISD7 = 0;				//PWM-pin ON
 	T2CON  = 0b00000101;				//timer2 on
	PR2    = 240;
	CCPR1L = 0x78;
	CCP1CON= 0b01001100;
timer0();
while(1);
void timer0(void)
T0CON=0b10100010;			//enable timer0
							//timer is configured as 16-bits counter
							//transition on TOCKl pin
							//increment on low-high transition on T0CKl pin
							//set prescaler
							//1:8 prescaler
	INTCONbits.TMR0IF = 0; 			//clear roll-over interrupt flag
	INTCON2bits.INTEDG0=0; 			// interrupt is falling edge
	INTCONbits.INT0IE=1;			// enable  interrupt
  	INTCONbits.GIEH = 1;           //enable global interrupts
	TMR0H = 0;                      // clear timer - always write upper byte first
    TMR0L = 0;
//Low priority interrupt vector
#pragma code InterruptVectorLow = 0x18
void
InterruptVectorLow (void)
  _asm
    goto InterruptHandlerLow
  _endasm
// Low priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerLow
void
InterruptHandlerLow ()
    if (INTCONbits.TMR0IF)
        LATDbits.LATD7=0;
		Delay1KTCYx(10);
        INTCONbits.TMR0IF=0;
