PatentLawyer
We are converting legacy lighted display boxes from fluorescent to LED. We have had inconsistent results depending on the power supply/dimmer and LEDs used. Our long time electrical engineer consultant sadly passed away and we are left scratching our heads. I know some LEDs require constant current and some constant voltage. Recently we have had 100% failures of the 3amp power supply used on nour smallest light boxes. We are using a PWM dimmer on the DC side and 3a is plenty for the LEDs used. First question: I can’t determine if the power supply pictured is constant current or constant voltage. I have been assuming constant voltage. What does the solid line above the dashed line between 12v and 3a indicate? Second question: could the PWM device on the DFC side cause the power supply to cook itself trying to maintain constant voltage? The units simply stop working after days to weeks of use. I am also attaching a photo of a ter-down of an LED module for reference. Any input would be greatly appreciated. You can see our art work at Austine [dot] com
