MrDestruction
Hey guys, I am new here!!! I been having some trouble with my inverter design. ok here's the deal i used transistors to drive my H bridge mosfet to put out a 12 Vac square wave signal. for now i am just simulating this in my multisim. I got the 12 vac output but when i send it to my transformer center tapped at 12 vdc. it gives me error. can someone help me. I am using a 555 timer IC. But i also tried just using freq. generator and running it through a rectifier to generate my PWM signal.
PWM - 5v 60Hz
how do you i attach my circuit on the site.
This is not an actual circuit i will be building i am just messing around to see if i can build a simple inverter.
12dc to 120 vac i am looking for.
PWM -> transistor drive -> H bridge Mosfet ->Transformer
thanks all for your help.
PWM - 5v 60Hz
