need help to understand php code
Parth86
Hello
I don't have knowledge about php coding. I am trying to understand the part of php program. its related to ip address. can anyone tell me whats happening in program. what's the use of this part?
C:
<?php
error_reporting(0);
if ($_POST) {
$file_path = "//192.158.0.100/PRASHANT/Device control/device_log.txt";
    $myfile = fopen($file_path, "w") or die("Unable to open file!");
    $txt = $_POST['device']." ".$_POST['switch']."\n";
    fwrite($myfile, $txt);
    fclose($myfile);
This just appends the file "device_log.txt" with an error. It writes which device and then the error then a new line..
does this code work in following manner
suppose there are two system ,server system and client system
1. client system try to obtained the ip address of server system and try to set connection
2. client system continuously check connection is successful or not if the connection is not successful then it will again try to obtain IP address of server system
3. If the connection is successful with the server system then the two system's are ready for the communication
I don't think so..
This is a web posing thing on receiving an error... This only opens a file and updates the a log.. so someone can debug at a later date..
I don't have knowledge about PHP programming that's why I posted small part of program to find out whats happening in program. I am trying to understand what the purpose of this program?
C:
<?php
error_reporting(0);
if ($_POST) {
$file_path = "//192.158.0.100/PRASHAN/Device control/device_log.txt";
    fclose($myfile);
<html>
<head>
<script type="text/javascript">
function beforeSubmit(device_val, switch_val)
   document.controll.device.value = device_val;
   document.controll.switch.value = switch_val;
   document.controll.submit();
<?php if($_POST) { ?>
var delay = 4000;
setTimeout(function() {
$device =  null;
   <?php if ($_POST['device'] == 'fan') {
       $device = 'Fan';
       } else if ($_POST['device'] == 'light1') {
       $device = 'Motor';
       } else if ($_POST['device'] == 'light2') {
                $device = 'Light';
       } else if ($_POST['device'] == 'light3') {
                $device = 'Light';
       if($_POST['switch'] == 'on') { ?>
       document.getElementById("<?php echo $_POST['device']?>").innerHTML = '<span style="color:lime;"><b> <?php echo $device?> is On</b></span>';
   <?php } else { ?>
         document.getElementById("<?php echo $_POST['device']?>").innerHTML = '<span style="color:red;"><b> <?php echo $device?> is Off</b></span>';
   <?php } ?>
}, delay);
<?php } ?>
</script>
</head>
