Hi all!
I am trying to interface two separate circuits. The first one I use to open a fuel injector for an adjustable period of time then close it. The second circuit then fires a single spark plug. The problem I am having is that I must be sure that the injector is fully closed before I fire the spark plug as I am using HHO gas in a pulse jet engine.
I just cannot seem to figure out how to time the fuel injector to the coil driver. I am only looking for about a 1 second delay after the injector closes. The system is 12 volts. I was thinking of either a capacitor between the two or a comparator to monitor the voltage from the injector so when it reaches 0v then the coil energizes.
The injector of course is adjustable as to the frequency of it opening and closes so I need something that will compensate for that as the frequency increases.
This is my first post here and I looked around and y'all seem very knowledgeable and helpful versus other boards. I like to learn so even if you point me in the right direction that would be great!
Here are the schematics.
Fuel injector circuit by RCM
Ignition driver via web
Thanks ahead.
Bingers
Thanks ahead.
Bingers
