n_vikranth
can any one solve my problem?
I planned to work with ZIGBEE, so i started with basic steps... Iam using Atmega16A microcontroller and mikroc pro compiler, I started with basic serial communication between two Atmega16A controller,bcos in ZIGBEE datasheet they mentioned that we can use module directly by neglecting wire medium… as per the datasheet I used only vcc,gnd,Din,Dout.
When I used wire it transmit data clearly,but when I used zigbee module it shows some black box in my lcd module…
Wat is the solution for my problem… kindly reply me.
I have doubt in Zigbee connections, I used 3v DC supply…
