Hi guys. I'm having a little trouble identifying how to use a sensor on my motorcycle. It's a speed pickup that is on the transmission. I don't have access to a 'scope (that would make it much easier). the pickup has 3 wires. One is 12V ignition power, second is ground, and 3rd is a 5V pulse. The pulse line leads directly to the instrument cluster. With the ignition on but not running, I can read a distinct 5V pulse while turning the rear wheel by hand, but the pulses are not related to wheel position, ie: if I turn the wheel forward until I get a pulse, then turn back a little, and then forward to the same place, I don't get a pulse. It is even more confusing because when I start the engine, I get pulses even when the wheel is not turning!
At first, I assumed that the sensor would be a simple Hall-effect switch, but the behaviour observed seems to indicate otherwise. Is there any way to check this without actually removing the sensor from the engine?
Also, I assumed that the frequency of the pulses would be proportional to the speed, but would it be possible for the signal to be PWM? So that the frequency is constant, but pulse width varies so as to drive the needle motor? Can a simple sensor put out a PWM signal?
Any help here would be greatly appreciated. I've finished programming my MCU, and it works fine using an astable 555 with variable timing up to 5KHz as input, but the bike's sensor is throwing a fish at me.
Alternately, I could place a few small magnets on the wheel rim, and place a separate sensor to detect their passing, but it would be far easier to simply tap into the existing sensors.
Thanks in advance...
