Hi there!
I'm considering to make a line follower and I have made this code:
It runs well on LEDs and hopefuly it will run on motors too. Actually the programme reverse one LED lightning the other on interrupt and ther are two such pairs of LEDs, so when motors will be connected on interrupt the respective motor will be reversed. If you don't follow what I mean than kindly see the video which is posted by "futz" who helped me with the codes and circuit..
Now what I'm confused is about the H bridge, I don't have much time to spend on this robot as my exams are coming, I was wondering that can't I simply connect motors with the PIC via resistors, will that be relaible ?.
I will use photoresistors as sensors (FYI).
list p=16f628
#include<p16f628.inc>
__CONFIG _MCLRE_ON & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
ERRORLEVEL -302
cblock 0x20
temp
temp_s
endc
org 0x00
goto main
;***********************************INTERRUPT LOOP*****************
org 0X04
inter:
movwf temp
swapf STATUS,w
clrf STATUS
movwf temp_s
btfsc PORTB,0x00
goto loop1
loop2:
movlw b'00000101'
movwf PORTA
btfsc PORTB,0x05
goto loop2
goto loop_x
loop1:
movlw b'10001000'
movwf PORTA
btfsc PORTB,0x00
goto loop1
loop_x
bcf INTCON,0x01
bcf INTCON,0x00
swapf temp_s,w
movwf STATUS
swapf temp,w
retfie
main:
bsf INTCON,0x07 ;Globel interrupt enable(we are using interr.)
bsf INTCON,0x04
bsf INTCON,0x03 ;RB4-RB7 interrupt on change is enabled/ in other words these pins will also work as
;interrupts and interrupt will occur every time any of these pin changes state
; i.e.:HIGH to LOW or LOW to HIGH, we can not set it to be on eather one state change
bcf INTCON, 0x01
bcf INTCON, 0x00 ;Clear RB4-RB7 interrupt flag so, that another interr. can occur.
;**********************************SET UP THE PORTS *****************
bsf STATUS,RP0 ;switch to BANK 1
movlw b'00100001'
movwf TRISB ;set RB6 & RB5 as input
movlw b'00000000'
movwf TRISA ;setPORT A all output
bcf STATUS,RP0 ;back to BANK 0
movlw 0x07 ;turn comparators off, so HIGH will be simple
; HIGH rather than +5V (compared to supply) so with the LOW
movwf CMCON
Loop:
movlw b'00001001'
movwf PORTA ;set pin 0 of port a HIGH
goto Loop
END
