The way I did it was define a smaller drill size in Eagle and edited the IC pads to be larger. I guess those tiny pads are fine if you are getting a professional PCB made and every hole is plated through, but it's a bugger if you are drilling by hand.Kyle-s4h said:The "pads" of the ICs are, well, not really pads at all by default -- just small circles -- not good when you need to drill though them. Well, I would think that the proper way to do it would be to drop in your ICs, then go back and add whatever style of pads to them. Anything that had square pads worked out great.
Do not give up on Eagle. It is worth the extra effort it takes to learn. You can ask questions here or in Eagles own support group. In Eagle you set the drill size. The pad size is determined by restring. Restring sets the copper pads size as a percentage of the drilled hole. Larger percentages makes larger pads for a given size hole. For boards that are to be drilled by hand there is a script called DRILL-AID. It reduces the size of the hole on the artwork. The smaller hole can be used to center the drill on the etched board.Andy1845c said:I really want to try this myself, but I can't get the hang of Eagle at all. ...
3v0 said:Do not give up on Eagle. It is worth the extra effort it takes to learn. You can ask questions here or in Eagles own support group. In Eagle you set the drill size. The pad size is determined by restring. Restring sets the copper pads size as a percentage of the drilled hole. Larger percentages makes larger pads for a given size hole. For boards that are to be drilled by hand there is a script called DRILL-AID. It reduces the size of the hole on the artwork. The smaller hole can be used to center the drill on the etched board.
Torben said:And your results have made me consider setting up a UV etching kit.
The nice thing about doing you own PCBs by whatever method is that you can stop hand wiring prototypes. The more you do the better/faster you get. Regardless of how you make the board you should visit the pulsarProFx site and checkout what he is doing for a silscreen. --- I do it a bit different. After the board is etched I paint the top side of the board white with fusion paint. Use toner transfer to place the black silkscreen layer over the paint. I seal it with clear conformal coating to keep it from scratching off. The only problem is that after you paint the board you can not use anything other then soap and water to clean it. Most anything else will mess up the paint and artwork. The liquid fluxes I have also mess up the board. --- One problem with DIY boards is that they do not solder as easy as ones made in a board house. After the board is etched I clean the copper and spray it with a thin coat of conformal coating. The coating keeps the copper from oxidizing. The conformal coating does not seem to bother the soldering process. Maybe the iron vaporizes it. Not sure but they do solder well.Kyle-s4h said:Two lines between the pads? Aw, yer just makin' me jealous now!![]()
picbits said:Don't talk to me about PCBs !!!
