My #1 Enemy SPI
AtomSoft
Hey im still trying to write some code for a 16megabit (2MB) SPI Atmel chip using a PIC. Here is my C source so far. The issue i suppose it im not getting data that im supposed to get back. Below is the code and a link to the datasheet of the Memory and the PIC im using. I think it has to do with setup of the SPI. Can anyone help me. Sorry for asking so much. But think about it.. i try for days before i ask here.
#include <p18f2525.h>
#include <stdio.h>
#include <delays.h>
#include <string.h>
#pragma config WDT = OFF, XINST = OFF, OSC = INTIO67
#define CS LATCbits.LATC2
#define readSPI() writeSPI(0xFF)
#pragma udata bigdata
unsigned char buffer[512];
unsigned char data[512];
#pragma udata
void main(void);
void Init(void);
void MemRead(unsigned char *addr,char *buff, unsigned int len);
void MemWrite(unsigned char *addr,char *buff, unsigned int len);
unsigned char writeSPI(unsigned char data);
char RdyBusy(void);
void SetSizeFT(void);
void main(void){
    unsigned char address = {0x00};
    char data2[] = {"Jason Rules and if you dont think so kiss my A*S lol"};
	OSCCON = 0x72;      			//8MHz clock
	while(!OSCCONbits.IOFS);		//wait for osc stable
    strcpy(data,data2);
    Init();
    while(RdyBusy());
    address=address<<9;
    MemWrite(address,data,512);
    while(RdyBusy());
    address=address<<23;
    MemRead(address,buffer,512);
	while(1){
	    while(RdyBusy());
void Init(void){
    ADCON1 = 0x0F;
    TRISC = 0x10;               //SDO(RC5),SCL/SCK(RC3),CS(RC2) = Output, SDA/SDI(RC4) = Input
    CS = 1;                     // Chip Select = OFF (Logic Low = Selected)
	SSPSTAT = 0b00000010;       //SMP(7)=0, CKE(6)=0 (clock edge idle to active)
	SSPCON1 = 0b00000000;       //CKP(4)=0 clock polarity (idle low) (Fastes FOSC/4)
                                //SSPM3:SSPM0(3:0)=010 spi clock FOSC/64 (<400kHz)
	SSPCON1bits.SSPEN=1;		//SSPEN(5)=1 enable SPI
    while(RdyBusy());
    SetSizeFT();
void MemRead( unsigned char *addr,char *buff, unsigned int len){
    unsigned int x;
    CS = 0;                 //Select the chip
    writeSPI(0x0B);         //Continuous Array Read
    for( x=0; x<3; x++)     //Send the Address (Page & Byte Start Address)
        writeSPI(*addr++);
    for( x=0; x<4; x++)     //Send the 4 Dont Care Bytes
        writeSPI(0x01);
    for( x=0; x<len; x++)     //Read the Data In (Clock it)
        *buff++ = readSPI();
    CS = 1;                 //DeSelect the Chip
void MemWrite( unsigned char *addr,char *buff, unsigned int len){
    int x;
    writeSPI(0x84);         //Buffer Write
        writeSPI(0x00);
    for( x=0; x<len; x++)     //Send the 4 Dont Care Bytes
        writeSPI(*buff);
    writeSPI(0x83);         //Buffer Write
        writeSPI(*addr++);
        writeSPI(*buff++);
char RdyBusy(void){
    unsigned char stat;
    writeSPI(0xD7);         //Status Register
    stat = writeSPI(0xD7);
    if((stat & 0x80) != 0)
        return 0;
    else
        return 1;
void SetSizeFT(void){   //Five Twelve (512)
    unsigned char stat;
    writeSPI(0x3D);
    writeSPI(0x2A);
    writeSPI(0x80);
    writeSPI(0xA6);
unsigned char writeSPI(unsigned char data){
	SSPBUF=data;
	while(!SSPSTATbits.BF);
	return SSPBUF;
PIC DATASHEET (18F2525)
AT45DB161D
https://www.electro-tech-online.com/custompdfs/2008/09/AT45DB161D.pdf
Short Description of IC :
https://www.sparkfun.com/commerce/product_info.php?products_id=301
ok i got it for anyone else out there lol I used the internal SPI Routines. With my own CS Here ya go.
FULLY TESTED and proud to say working 100%
#include <stdio.h>
#include <delays.h>
#include <string.h>
#include <spi.h>
#define CS LATAbits.LATA5
#define readSPI() WriteSPI(0xFF)
#pragma udata
void main(void);
void Init(void);
unsigned char WriteSPI(unsigned char data);
char RdyBusy(void);
void main(void){
    unsigned short long address = 0x00;
    unsigned short long address2 = 0x00;
    strcpy(data,data2);
    Init();
    while(RdyBusy());
    address=address<<9;
    while(RdyBusy());
    address2=address2<<23;
	while(1){
	    CS = 1;
void Init(void){
    ADCON1 = 0x0F;
    TRISAbits.TRISA5 = 0;
    OpenSPI(SPI_FOSC_4,MODE_00,SMPMID);
//	SSPSTAT = 0b00000001;       //SMP(7)=0, CKE(6)=0 (clock edge idle to active)
//	SSPCON1 = 0b00000000;       //CKP(4)=0 clock polarity (idle low) (Fastes FOSC/4)
//	SSPCON1bits.SSPEN=1;		//SSPEN(5)=1 enable SPI
    while(RdyBusy());
    SetSizeFT();
    unsigned int x;
    WriteSPI(0x0B);         //Continuous Array Read
        WriteSPI(*addr++);
        WriteSPI(0xFF);
    int x;
    WriteSPI(0x84);         //Buffer Write
        WriteSPI(0x00);
        WriteSPI(*buff++);
    WriteSPI(0x83);         //Buffer Write
        WriteSPI(*addr++);
        WriteSPI(*buff++);
char RdyBusy(void){
    unsigned char wait;
    WriteSPI(0xD7);
    wait = WriteSPI(0xD7);          //Status Register
    //stat = stat & 0x80;
    if(wait != 0)
        return 0;
    else
        return 1;
    unsigned char stat;
    WriteSPI(0x3D);
    WriteSPI(0x2A);
    WriteSPI(0x80);
    WriteSPI(0xA6);
Sometimes when you put it out there for others to look at you'll take another look yourself and find the problem(s)...
Congrats'... Looks like a neat memory...
Mike
LOL! :D Good work. Nice to know there is a simple SPI chip that can store large amounts of data without the complication of using an SD card and FAT.
#include <stdio.h>
#include <delays.h>
#include <string.h>
#include <spi.h>
#pragma udata
void main(void);
void Init(void);
char RdyBusy(void);
void main(void){
    strcpy(data,data2);
    Init();
    while(RdyBusy());
    address=address<<9;
    while(RdyBusy());
	while(1){
	    CS = 1;
void Init(void){
    ADCON1 = 0x0F;
    while(RdyBusy());
    SetSizeFT();
    unsigned int x;
        WriteSPI(*addr++);
        WriteSPI(0xFF);
    int x;
        WriteSPI(0x00);
        WriteSPI(*buff++);
        WriteSPI(*addr++);
        WriteSPI(*buff++);
char RdyBusy(void){
    unsigned char wait;
    WriteSPI(0xD7);
    if(wait != 0)
        return 0;
    else
        return 1;
    unsigned char stat;
    WriteSPI(0x3D);
    WriteSPI(0x2A);
    WriteSPI(0x80);
    WriteSPI(0xA6);
hello, would you be so kind as to show me what's in spi.h? im trying to convert your program using CCS C. thanks in advance..
