Boncuk
Bonuk
You obviously haven't read the last couple of posts .
When I was referring to the relay or transistor output we were discussing the coin mechanism in an arcade machine, not the timer. Read the last couple of posts carefully before you post.
Hi Airman1,
that's definitely the best way to discourage (p. them off) any member to answer your posts.
There is a minor difference between input and output!
The output of your arcade machine is an input for your timer circuit!
If you don't name the "terminus technicus" properly you haven't understood a bit about electronics!
Failing to understand the problem is not anybody else's fault but only yours!
I suggest to contact the author of the article to answer your more than silly questions and handle the also more than silly problems you have.
Boncuk
