MPlab XC8 eeprom access PIC18F4685
revave
Hello,
For a project i need access to the internal eeprom of a PIC18F4685.
I use the functions below, but it didn't work. Can someone tell what i'm doing wrong? I'm using the latest version of MPlab X and XC8.
Eeprom memory is not code protected and no interrupts are used..
//EEPROM routines
char rd (char e_addr)
EEADR = e_addr; //Data Memory Address to read
EECON1bits.EEPGD = 0 ; //Point to DATA memory
EECON1bits.RD = 1; //EEPROM Read
return EEDATA;
void wr (char e_addr, char e_value)
EEADR = e_addr; //Data Memory Address to write
EEDATA = e_value; //Data Memory Value to write
EECON1bits.WREN = 1; //Enable writes
EECON2 = 0x55; //Write 55h
EECON2 = 0xAA; //Write AAh
EECON1bits.WR = 1; //Set WR bit to begin write
while (EECON1bits.WR)continue;
EECON1bits.WREN == 0;
The only difference between your code and mine (works okay ) is the CFGS register and I disable the global interrupts..
The code I use was ripped from the peripheral library on the old C18 compiler...
I had to change the interrupt as there was a bug in the C18 library..
C:
unsigned char ReadEeprom(unsigned int badd )
   EEADR = (badd & 0x0ff);
   EECON1bits.CFGS = 0;
   EECON1bits.EEPGD = 0;
   EECON1bits.RD = 1;
   return ( EEDATA );  // return with read byte
void WriteEeprom( unsigned int badd,unsigned char bdata )
   EEDATA = bdata;
   INTCONbits.GIE = 0;
   EECON2 = 0x55;
   EECON2 = 0xAA;
   EECON1bits.WR = 1;
   while(EECON1bits.WR);
   INTCONbits.GIE = 1;
   EECON1bits.WREN = 0;
Dear Ian,
Thank you for your very quick reply.
Finally with your code it works.
Thanks for your help..
Best regards,
Reijnko Vast
Ian is like Wyle Coyote. Super Genious. :D
