Hi! My third study...
I have some HD motors and according to my research, they are stepper motors. But I can't find anywhere a simple way to drive those HD motors. Any clue?
Many thanks!
Your research is wrong, they aren't stepper motors.
Coil 1 signals
Phase 1 .....| |.........|
Phase 2 ..... .........
Coil 2 signals
Phase 3 .| |........| |....
Phase 4 |........| |.........|
The signals can be presented also in binary format. The common sequence (1 means current flowing, 0 means open circuit):
Phase1 00110011
Phase2 11001100
Phase3 01100110
Phase4 10011001
Brushless DC motor.arhi said:The main problem testing this is if you start the sequence too fast, nothing will happen (or disk motor will move left/right irrationally ) and if you start to slow, the same thing will happen. Bit's me why, probably because they are not "stepper" but "something something DC something" motors...
Wow! Thank you ericgibbs!Using disk drive motors
PCGuide - Ref - Hard Disk Spindle Motor
Walzing Hard Drive Motors | Let's Make Robots!
Ouais ouais... now I know!Your research is wrong, they aren't stepper motors.
Brushless DC motor.
As I understand it the motor has to be able to rotate with the cycle rate. If the cycle rate is too much faster or slower then the motor is currently turing it will not react as expected. You need to ramp the speed(cycle rate) up and down.
