missing interrupt on PIC16f690
teragiga
Hi
I am having some trouble on a PIC16F690:
I generate a interrupt using a monostable multivibrator of a 556 as described here and depicted here:
http://www.kpsec.freeuk.com/555timer.htm
The output is connected to a LED diode and to the RA1 port of a PIC16F690.
The output of the timer is used as an interrupt as the following code:
//Interrupt Handler
void interrupt ISR( void )
unsigned char dummy;
// Is this a port change interrupt and is it enabled?
if( RABIE && RABIF )
if( RA1==1)
do something.....
dummy = PORTA; // clear port mis-match
RABIF = 0;
The PIC is perfectly working if I connect the output of the timer to RA1. When I also connect the LED diode, the PIC stops detecting the the interrupt, as if the current/voltage was not enough since is suck up by the LED. Is there a minimal current/voltage to be detected as an interrupt by the PIC ? How can I make the PIC works together with the LED ?
Best.
Do you have a resistor in series with the LED.???
