microphone input -> speaker input
davejs
Hi
I am new here and dont have lots of knowledge of what i am trying to do but here is my question.....
I have a small device that can record sound when you press a button via an inbuilt mini microphone. This is then played back when another buttin is pressed. Very simple.... but i want to record sound direct into the device via my pc. (not through air into microphone)
I have removed the microphone from the device and soldered the wires from PC speaker direct onto the two remaining microphone connections!
This does actually work when i playback music from pc and then press record button on device BUT the resulting recorded sound is distorted when it is played back.
If i adjust volume on pc speakers as i record into the device it does not seem to change the level of distortion although the recording does reflect the volume change... but distortion remains.
I am guesing i can not simply expect the microphone input connections to accept what ever is coming down my speaker wire!!
Anyone have any advice as to how i would go about working out how to make this work without distoted sound being recorded?
Maybe a simple explanation of speaker and microphone electronics would also be a good idea, i have looked this up and think i am correct in thinking speaker wire is outputting variable AC levels depending on volume but thats about as much as i understand!
Cheers
Dave
The output level from a microphone is only about 0.01V so the preamp has a lot of gain.
But the output level from a speaker is a few volts which is 500 times too high to feed into a mic input even if the speaker volume control is turned down.
You need to make an attenuator with two resistors.
