Microchip C18 : Function Declaration
Firstly, hope the thread title is not misleading (it probably is) but not sure how to title this question. I'm positioning a cursor on an LCD screen. Works ok, done it loads of times in previous programs. But trying to make the code a little 'neater / tighter'. This is what I have been doing thus far...
void LCD_data_init (void)
    clrscrn();
    csrpos = 0x8F;
    putcsr();
void putcsr (void)
    data2LCD = csrpos;        //Line x Coloumn x
    write2LCD();
I might be mistaken but I think I've seen something like this somewhere that would be neater...
    putcsr(0x8f);
void putcsr (char)
    data2LCD = putcsr;        //Line x Coloumn x
    write2LCD();
What's wrong with the second two code snippets? Any help greatly appreciated.
Thanks in advance.
Change the final code that you show to the following:
void putcsr (char pos)
   data2LCD = pos;
   write2LCD();
At the top of your c file (or in a header file included in any c file from which you call the function putcsr) add the following line:
void putcsr (char pos);
Also, consider what putcsr(0x8f) looks like. I can guess that you're putting the cursor somewhere, but I don't know where it is going. Will you know where it is going a year from now or will you have to look at the display datasheet? Consider using a #define
#define TOP_LEFT_CORNER  0x8f
    clrscrn();
    putcsr( TOP_LEFT_CORNER );
   data2LCD = pos;
   write2LCD();
or even better, do something like the following (I have NO idea if this is how the display works or not)
#define ROW_1  0x80
#define ROW_2 0x40
#define ROW_3 0x20
#define ROW_4 0x10
#define COL_1 0x00
#define COL_2 0x01
#define COL_3 0x02
#define COL_16 0x0F
    clrscrn();
    putcsr( ROW_1 | COL_16 );
It would be better to rewrite write2LCD to take a value,
void write2LCD(char dat){
    write2LCD(0x8f);
Using global variables to pass parameters is very wasteful and can easily lead to bugs.
I agree entirely.. but write2LCD() might be at the lowest level and stack could be an issue! ( Yes!! I know in this case it won't, but caution needed, I don't know the ram size)
