Micro controller Programming
Comparison is simply "==" in C language. If you want more help than that, then you need to provide more info to me.
Show me the code that reads the NFC tag and the code that takes the user input.
Again!!! I want to see an example of what you need...
IncommingString = "-----------"; // what is in this UID string?
WantedString1 ="-----"; // What will end up here ?
WantedString2 = "------" // What will end up here?
Is it possible to Read the Arduino's EEPROM values and display it in URL using ECN28J60 Module
Of course it is... There is an EEPROM library in your IDE and your Ethernet shield will also have a library..
Is it possible to lock particular block alone in NFC tag using Arduino. If yes plz reply with sample code...
Thanks in advance for anybody who going to help me
using Arduino I want to read Serial data
if Serial data = GET01000300
it should print Read
if Serial data = SET01000300
it should print Write
Please anybody help me i'm not good with programming...
Thanks in advance!!!!!!
How to connect YL-30 SD shield with Arduino Uno.
Please post the sample program to test it and also post the link to download the library file for this particular shield
Usually Arduino shields are designed to be just pushed in place (on top of the Arduino). That is why they are called "shields".
#include <DS1307RTC.h>
#include <Time.h>
#include <Wire.h>
void setup() {
Serial.begin(9600);
while (!Serial) ; // wait for serial
delay(200);
Serial.println("DS1307RTC Read Test");
Serial.println("-------------------");
void loop() {
tmElements_t tm;
if (RTC.read(tm))
Serial.print("Ok, Time = ");
print2digits(tm.Hour);
Serial.write(':');
print2digits(tm.Minute);
Serial.write(':');
print2digits(tm.Second);
Serial.print(", Date (D/M/Y) = ");
Serial.print(tm.Day);
Serial.write('/');
Serial.print(tm.Month);
Serial.write('/');
Serial.print(tmYearToCalendar(tm.Year));
Serial.println();
} else {
if (RTC.chipPresent()) {
Serial.println("The DS1307 is stopped. Please run the SetTime");
Serial.println("example to initialize the time and begin running.");
Serial.println();
} else {
Serial.println("DS1307 read error! Please check the circuitry.");
Serial.println();
delay(9000);
delay(1000);
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
i haave got error : expected primary-expression before '.' token
Thanks in advance
