Measuring Pulse width
autaorte
How i do for measuring Pulse Width in C langue? (Pic 16f628A)
Any guy have a example?
boxer4
I've never seriously messed with 16F628A interrupts to measure pulse widths, but for a AVR I'd set an interrupt pin to trigger on both edges, and simply measure how many clock ticks with a timer it stays in each state.
For the 628A it looks like PORTB has an interrupt option on state change. You can probably use one of portb 7:4 to do something similar.
If you're out of resources you may have to use a tight loop to check if the port changed state or not, I'd probably avoid this method unless the pulse widths are quite a bit longer than several instruction cycle time.
Pommie
Most Helpful Member
The hardware will do it for you. Read the section in the data sheet on the CCP module.
EE World Online Articles
Loading
