Measuring Pulse width
autaorte
How i do for measuring Pulse Width in C langue? (Pic 16f628A)
Any guy have a example?
I've never seriously messed with 16F628A interrupts to measure pulse widths, but for a AVR I'd set an interrupt pin to trigger on both edges, and simply measure how many clock ticks with a timer it stays in each state.
For the 628A it looks like PORTB has an interrupt option on state change. You can probably use one of portb 7:4 to do something similar.
If you're out of resources you may have to use a tight loop to check if the port changed state or not, I'd probably avoid this method unless the pulse widths are quite a bit longer than several instruction cycle time.
I have a few examples measuring 1 to 2ms pulses on my site. See 'pulse width', 'port mirror', 'lvc1' and 'lvc2' here: **broken link removed**
Regards, David.
The hardware will do it for you. Read the section in the data sheet on the CCP module.
