Magnetic Contacts
Does anyone have a place they've bought magnetic contacts before (like the power connector on Apple computers)? Is it possible to solder to Neodymium magnets and use them as electrical contacts? Thanks!
Surprisingly, there seems to be an answer when I searched on, "can neodymium be soldered."
Check #20 here: https://www.kjmagnetics.com/FAQ.asp#weld
Also, Wikipedia confirms: "Neodymium metal tarnishes slowly in air and it burns readily at about 150 °C to form the neodymium(III) oxide."
You might find some low-melting solder made with indium, gallium, etc. that might work (wetting will be a problem), but why not just use springs for your contacts?
John
Edit: BTW, since neodymium oxidizes so readily in air, you will need to protect any soldered surface. In fact, the surface of your magnet is probably not neodymium, but rather a plating like nickle or chrome. Soldering to nickle is possible, but temperature may still be a problem. So first, find out exactly what your magnets consist of. You may get by with a flash plating of gold or copper followed by low-temp indium-alloy soldering. Some bismuth alloys may also work.
I would not solder onto a neodymium magnet as most are low temp magnets and neodymium magnets DO NOT recover from heat, so you will demagnetise your magnet with heat.
neodymium magnets come with a heat rating like N for 80C and M for 120C and most dont go higher than a M rating.
The higher the rating the greater the price, so most cheaper magnets will have a low temp rating.
What i have done is to solder onto a nickle plated steel washer and just stuck that to the magnet, as they are powerful little suckers and it will contact well.
You could use the metal end from a dead AAA battery to solder onto instead of a washer.
If you use a thicker bit of steel on one side of the magnet and a thinner on the other, the magnet will remain stuck to the thicker piece, and the thinner piece will disconnect from the magnet.
Pete.
