0.5C fine.For the time being also I'm displaying 0.5C.Ex:26.5
ericgibbs help me to stop this jitter thing.
.When it’s changing its value between two points the display is getting jitter. Means it will show 26.5 & when reaches 27.0 it will shift between these two values 26.5, 27.0,26.5, 27.0……so the display is not stable always shift between two values
or amplify the LM35 signal by times 5 as shown in the OPA circuit.
I have no free analog inputs so the only solution is to amplify the LM35 signal by 5 times & feed it to PIC AD.
ericgibbs have you made a temperature display (SSD) like I build using LM35 didn't you get a similar jitter thing?
In your diagram there is a voltage gain formula.Can you tell from where is that [*5] comes?
Hi ericgibbs now I understood a bit how the jitter will affect.Can you tell me how did you get that 0.1C accuracy when I amplify the signal by 5?
By adjusting the gain, the adc can be set to give 1000 counts for 100C, so you can see its a direct conversion to ASCII to display the tempr.
Which still may not correct the jitter.
What about conversion speed? I'm going to assume conversion speed is running on a pretty slow clock?
oops sorry eric when I amplify the signal by 5 how did you get the 0.1C resolution?
Hi ericgibbs & Hi sceadwin now only I got the point.
Earlier I used 204 counts to represent 100C, that is 0.49 almost 0.5C resolution. Due to noise it will vary with big gaps like 0.5C.
If I set up the input with a gain of 5 then it will have a resolution of 0.1C = (100temp/1000steps). Due to noise it will vary with smaller gaps like 0.1C.
If I setup for a 0.1C resolution & display the results to a 0.5C then it will work nicely.
But if I setup for a 0.1C resolution & display the results to a 0.1C then it will still have the problem.
Hi eric I made your circuit & checked, it worked, but you have to take more samples & average the result. The display is stable but when the temperature moving stage the jitter occurs. This can be eliminated by increasing sampling time ex: 0.1Sec etc…..
Whats your idea. In your LM35 project did you oversampled?
By how much does it jitter.??
