Low Cost Low Power RGB LED Recommendation?
Mike - K8LH
Can anyone recommend a decent low-cost low-price RGB LED, please? I don't mind ordering from one of the Chinese vendors on ebay, if you've had good experiences with them.
I'd like to experiment with color fading/mixing algorithms, but, as always, I'm on a tight budget.
TIA. Cheerful regards, Mike
Here is a part that is through hole so it should be easy to experiment with. (not surface mount)
$1.65 for one at digikey.com
$1.40 each at 10.
You are in the USA so you might try RadioShack.
Thank you, guys. I appreciate the suggestions.
Has anyone tried RGB LEDs from the Chinese vendors? Prices of 8 to 10 cents per LED (quantity 100) is really tempting.
I purchased a hundred 3mm 2-pin red/green LEDs from China a couple months ago and I'm quite pleased with the quality (pictured below on a CDP1802 Cosmac ELF clone).
A few years ago I purchased some RGB LEDs from ebay. Very surprisingly, the red element is much dimmer than the green or blue. This was several years ago, so I'm not going to mention where they came from. This may have been a bad batch and quality may have improved.
jfyi, the cree leds I mentioned are very much hand iron solderable:woot:, all the items I ever list are all hand iron solderable, and those are pretty easy to hand solder:)
Do you have any pictures of projects using those, Joe? I'd love to see them...
TIA... Mike
these are the only pictures of that led in use that I still have, the brd is used in the "wally" vehicle in the vedio. I got burglarized last year:arghh:011.jpg this one is a Avago white led with a similar package except for the lens. I have ordered more of the Cree leds but they haven't arrived as of yet, I'll be using them for a motorcycle lighting display.
