Low battery indicator(low cost)
adrian sphank
Hello, i want to design a simple low battery indicator which using LED and 'buzz' sound like hand phone (warning buzz).:) Im looking forward at this design.
But where is the connection to the circuit?
The connection to the battery is the 9V input. It's designed to test a 9V battery.
6.9V is also a bit too high for a cut-off voltage, I would have chosen 6V, even 6.2 will probably be all right, just change the zener to 5.6V which is a pretty common value.
With the dimensions given both LEDs will light at full battery power.
Here is the modified circuit. The zener used is 5.1V.
UBatt >6.2V = green, UBatt <6.2V >5.5V = green + red, UBatt <5.5V = red, UBatt <4V = no LED
Boncuk
The problem with the circuit above is that they will drain the battery fairly quickly. This is because they draw apx 20ma which means that a regular 9V alkaline will be dead in apx 30 hours even if nothing else is connected.
Boncuk
How if i want to implement the 'buzz' sound?:D
If you use low current LEDs (2mA) and appropriate current limiting resistors (3K9 instead of 330Ω for 9V) the battery will stay alife longer. Adding a buzzer circuit I suggest to use a dual astable multivibrator (both gated) using a CMOS 4093 and connect a transducer to the output.
With the gated osicillator you'll have an intermittant tone signal which is more alarming than a steady signal. Additionally it uses less battery power.
Boncuk
Add the buzzer parallel with RED LED right?
Not quite. Referencing Boncuk's diagram; connect the buzzer between the collector of Q2 and +9V. Or, to put it another way, in parallel with the D3/R5 network.
Thanks!!!Understanding confirm!!!!!!
Additional question : How i want to have 'warning' sound like nokia Hp?
I have no idea what a "nokia Hp" sounds like. Maybe someone else does.
If you need a pulsed tone, you can get piezo buzzers that give a pulsed tone.
If you want anything more complicated than that, then you're outside the realm of simple and cheap.
