looking for linear actuator with return spring
jimbo1212
I am looking for linear actuator with a return spring the retracts the shaft when power is interupted. The shaft travel only needs to be 5 inches and the actuator can be AC or DC. 15lbs or less of thrust should work for my application.
I am aware of rotory actuators with a return spring but that won't work for my application.
Thanks,
Jim
Is the speed that pneumatic cylinders travel, or don't you want to run a compressor?
If it's a speed issue you can run air over oil to get the speed just right.
How fast? Is a lead screw permissible? I guess not, if a spring has to be able to return it on power interruption.
That's a pretty tall order for a solenoid or similar device. Can you consider a 75-lb pull (1" throw) solenoid with a 5:1 lever?
With a DC motor driven linear actuator, you could have a backup battery...and a circuit to detect power failure, drive the actuator home, and shut down.
Ken
I was hoping to avoid the pluming involved with using air plus having a supply of air. Electrical solenoids have been attempted previously by others with mixed results. The solenoids tended to burn-up over time when used with a level system due to either excessive resistance or jamming. My goal was to allow the spring to retract the shaft when power was interrupted.
Plumbing is not a real issue with these
I guess the real problem would be the air thing, but probably the one I would choose.
