Look uo table
GreenP
Hi Everone
I am trying to implement a look up table to drive a seven segment display in C
could someone please advise me?
Green P
Advise you on what? If you need a lookup table, use one.
If you want a lookup to select which segments to light for each digit I do it like this.
First define the bit needed to light each segment. Your hex values will differ from mine.
#define SEGA 0x20
#define SEGB 0x01
Then declare an array with the segments needed to construct each digit
const unsigned char digit[] = {
  SEGA | SEGB | SEGC | SEGD | SEGE | SEGF,  // 0
  SEGB | SEGC,  // 1
  SEGA | SEGB | SEGG | SEGE | SEGD,  // 2
  SEGA | SEGE | SEGF | SEGG // F
to display a '1' on a given digit set the port wired to the segments to digit[1];
