Logic statement in assembly language
Parth86
I want to write assembly code for 8051
switch A is connected to P0.1
switch B is connected to P0.2
LED is connected to P1.0
IF both switches high then the LED is turn on otherwise turn off
switch A high then turn off LED
switch B high then turn of LED
both A B high then turn on LED
both A B low then turn off led
I want to write assembly program using AND logic statement
How to write statement for AND logic for switches
The command ANL works with a byte so
ANL B, #FF ; and's B with 0xFF...
You need to test individual bits...
ie..
LOOP:
JNB P0.1, OFF ; switch 1
JNB P0.2, OFF ; switch2
SETB P1.0 ; LED on
SJMP LOOP​
OFF:
CLR P1.0 : LED off
SJMP LOOP​
ie..
LOOP:
SETB P1.0 ; LED on
SJMP LOOP​
OFF:
CLR P1.0 : LED off
SJMP LOOP​
I am confused it means I don't need to write statement in program I can use only loop for AND logic
I suppose you can really.. As both switches are on a single port..
so...
ANL P0 , #6 ; And Port 0 with 6 ( P0.1 and P0.2 )..
But I don't think that's what you want it to do!!
In the little example, I check switch 1.. If its on then I check if switch 2 is on.. Only then do you switch on the LED
p
so...
please clear one thing all logical operation can be done in accumulator so where and how to use acc in above program
ANL Is used by the Acc only... Sorry about that... A quick look at the datasheet says it can... But it can't.
This works... with bit test..
    org     0000h        ; Reset vector.
    sjmp    start        ; Jump over vector space.
    org    030h
start:                ; This will be assembled at 0x30.
    clr    p2.0        ; Turn LED off
    mov    P0,#6        ; Inputs...
while:
    jb    p0.1, turnon    ; Test switch 1.
    jb    p0.2, turnon    ; Test switch 1.
    clr    p2.0        ; Turn LED on.
    sjmp    while        ; Or go back to LABEL (while)
turnon:
    setb    p2.0        ; turn LED OFF.
    sjmp    while        ; end while
end
This is with a ANL command
    org    030h
while:
    mov    A,P0        ; Copy switches to Acc
    ANL    A,#0x6        ; Test which are on / off
    jnz    turnoff        ; both on.. if not zero
    clr    P2.0        ; one or more are off
    sjmp    while
turnoff:
    setb    p2.0        ; turn LED ON.
end
Oh!! Ignore that... I was just having a whinge at the datasheet... As you know they are not always clear about some commands.
If you look at the table it doesn't specifically state the accumulator..
