Dr_Doggy
I am using this chip to drive my led matrix from a 7.4v source, but I am noticing heat on it, i used it so that it would provide sufficient current weather 1 or 25 led's were on, 20ma to 500ma + supply for 8 IC's
theres not that much heat, but it has me considering installing heat sinks for long term runs
I think this problem is effecting the uC timing since the serial port uploading works 95% of all times, but I switched over to Bluetooth serial link which seems to work on the first few runs, but after a min or 2 my checksum byte returns 0 or double, MAYBE this is another problem that i am overlooking??
also i know the instructions said to use capacitors, to remove ac flaws?, which i didn't but so far it hasnt been a problem, could this contribute to the heat?
I am also thinking about putting 2-4ohm resistor between the source and lm7805 maybe it will reduce the stress on the IC?
then again maybe i should cut out the 7805 and just use a volt divider with resistors?
