LM3914 Question, Help!
TheSwede73
Hi again, i know i have asked some of you about this before, maybe im a slow learner :)
My main question is.
Can anyone maybe take a photo of a simpl circuit with the lm3914, with a potentiometer connected so you can adjust the leds on a bargraph, 10 leds.
I have it connected to a breadboard, but i just dont know how to connect everything...
So, the lm3914, a 10 led bargraph, potentiometer, battery.
Thanks!!
Thanks!!
Connect one end of the pot to +5V and the other end to 0V,, wiper to +5Vinp
Thanks!
And " - " from the battery to ground? at pin 2 or am i totally lost here :)
This a common cause of confusion.
The battery -V terminal is the 0V common connection, drawn as an upside down tree.! OK.?
Next question :)
If i read the schematic it looks like the V- and the +5v (with the pot, between) is connected together... via the dotted line with the capacitor....
I know its much to ask, but could you write excactly where everything connects... i would really appreciate it!
Thanks again!
/Anders
The circuit does not have a V- negative supply. Instead it has +5V, +6.8V to +18V and 0V which some people call ground.
The capacitor with dotted wires has its negative wire connected to 0V and its positive wire is connected to V-LED.
The pot has one terminal connected to 0V and the other terminal connected to +5V.
Are you from this world? or the matrix? :)
Thanks... what would i do... nobody seems to be interested in electronics in Sweden... but i just love it, i dont know so much, obviously.... i have about 20 000 leds, all kinds... but i dont know much about circuits...
Thanks for being there!, i'm so happy!
I hope you don't mind me asking questions, i can't really be of much help myself....
/Anders
Still no lights
Hi again!
Is it neccessary with the capacitor?
I just can't get it to work...
I have +5v to one leg of the capacitor, the middle leg on the 5-pin (signal) on the Lm3914.
But then the other leg of the pot seems to be connected to 0V.. where do i connect the (+) side of the leds, the one's that are joined togheter.
Thanks!
Thankyou!
I'm sure!, im on my way to buy a lab-powerunit now, i hate messing with batteries that needs recharging and so on...
After that i will try.
But again, is the capacitor needed?
And now i understand that i need two powersources?, didn't get that in the beginning...
One that provides 5 volt and one 9-12V
Thanks again!
Thankyou!
If the LED's are more than 6 inches from the LM3914 then Yes.
You can use a resistive divider to give the 5V from the 12V.
Thanks again!
Assume your psu is 12V output.
And your signal pot is 10K.
So you have to drop 7V in a series resistor from the 12V...
I'll do a sketch give me a minute.:)
EDIT:
Connect a 14K resistor from the top of the 10K pot as shown, this will give the 10K pot a range of 5V.
If you only have a 15K resistor, then this will give 4.8V across the pot.
OK.?
BTW: a 220K in parallel with a 15K should give about 14K....
Thankyou!
Never use rechargable batteries for prototyping unless you're 110% confident the circuit is working and you haven't shorted anything out.
Rechargable batteries give out a whopping great current and will fry/melt/vapourise anything in their path if you've got a short.
Thanks!
I have always been using batteries...but from today a labunit..
Wow, much new information here :)
I will study it, and if you have the time and could draw a new schedule i would really appreciate it, but you dont have to, i have gotten much more help than i deserve already :)
Thanks!
And stuck again, damnit...
Do i have to connect everything like in the picture? like from pin 7 to 6 and so on or are those for other applications?
Stuck again, damnit...
Do i have to connect everything on the schematic? the 7 pin with the 6, and the two resistors there or is that for other applications?
It will not work if pin 6 is not connected to pin 7.
Every part and every connection in the schematic has a reason.
The only optional connection is pin 9: Connect it to the positive supply for a bar-graph and leave it disconnected for a moving dot.
I see!, i thought this schematic was for many different applications, then i get it..
The resistors from pin 7, are they the same value always, unaffected by the choice of 9 or 12 volts?
The resistor values shown are from the application datasheet, to suit a 5V input signal and all pins MUST be connected as per the drawing.
The values will suit 9 or 12V operation.
Do you have the LM3914 datasheet.?
Datasheet Archive - Free Datasheet Search Engine :: PDF Datasheets :: Data Sheet :: Datasheet :: Application Note : ??? : ??? : ???? : ????? : ??????? : Fiche technique : Datenblatt : ????????
