LM3914 external refrence?
Llamarama
Hello everyone, I'm trying to get a 20 segment driver by chaining a pair of LM3914s as per the datasheet, but i'm having trouble with the voltage reference pins. Is there any way I can manually set a high reference and a low reference (say with a pair of 1k multiturn potentiometers) whilst sticking in a fixed resistor to set the led current/brightness?
I don't know what values of inputs i'll be using yet, but more than likely between 0 and 5v. Also, would it be ok to run this circuit from 9 or 10v? In many of the circuits i've seen online, the supply voltage is at least twice the input voltage.
Any pointers would be greatly appreciated. Many thanks, Mike.
Yes, you can do that. Connect Rhi and Rlo only to your respective refs, connect pin 8 to ground, connect the current-programming resistor between pins 7 and 8. Ok to run from a supply up to 15V.
Just note that the LM3914 power dissipation goes up with the supply voltage and the LED current, especially in the Bar mode.
Sorry to be a burden once again, I've been breadboarding layouts all night with little success. I can get a 10 segment version to work fine, but the 20 segment version doesn't work past 9 segments.
Once the 1th segment lights, it sticks and no further LEDs light up, this is when I feed it 4.5v.
I have (hopefully) attatched a schematic showing the circuit I'm using, does this look ok?
Right, it works fine for bar mode, however when connecting pin 9 of lm3914 1 to pin 1 of lm3913 2, and pin 9 of lm3914 2 to either pin 11 or completely disconnected as is mentioned in the datasheet, I get led 10 lit as soon as the lower scale in exceeded and it stays on. Any ideas as to why this is happening?
Here you go...
one shows circuit
one shows DOT graph
one shows BAR graph
eT
