I'm trying to make hi-side current sensor.
I used circuit from https://www.intersil.com/content/dam/Intersil/documents/an18/an1827.pdf and modified it by using separate power supply, so no need to use rail2rail opamp, because signal level is only about 1.4v greater than opamps's ground (this voltage is set by two diodes and resistor r3). Also I added zenner diode to protect opamp when there is short circuit in load, because i'll use it for lab power supply and output voltage can reach 60v
In ltspice it worked well, but in real life I used LM358 and i found out that it has low gain when differential voltage is low. My self-made shunt resistor has a voltage drop about 10mv per 1A and with 100r and 1k resistors circuit should have gain 10. But it only reaches normal gain (8 because shunt is not exactly 10mv/A, but i calculated like 10mv) when differential input voltage is greater than 6-7mv and can't sense 0-5mv, but I want to have current regulation in 0-1A range too, and can't increase shunt resistance, because power supply will be atx smps based i can get 50A from it on low voltages
Here is my circuit and results of measuring
What opamp i should use? And I haven't found gain on small differential signal in lm358 datasheet, which parameter I should look at? Can someone advise some cheap opamp with good characteristics for my case, which i could get on ebay?
