wanna_eat_1kg_of_elecons
Hello all,
I am looking at galvanic isolation for analog signals. I think I need a linear opto as there is a feedbackloop which will compensate for temperature and aging of the part. I am new to this subject and read some datasheets,
like these ones:
https://www.ixysic.com/home/pdfs.nsf/www/LOC110.pdf/$file/LOC110.pdf
https://www.ixysic.com/home/pdfs.nsf/www/AN-107.pdf/$file/AN-107.pdf
(1)The main question is what accuracy can I expect? In the AN-107 they tell the accuracy of the LOC110 is max 14 bits is this just advertisement talk or can I really achieve this?
(2) Of course there are other brands selling similar devices. Like vishay sells the IL300 etc. In those documents they talk about maximum 12 bits accuracy. I have not found devices with a higher accuracy (higher than 14 bits). But maybe there are devices that can easy do higher accuracy, has anyone got experience with these devices?
(3)I ask this because I want to use them and learn how to calculate accuracies It would really like to get a idea what they are talking about for instance in the application note of the IL300 datasheet they tell:
The IL300’s 130 dB common mode
rejection (CMR), ± 50 ppm/°C stability, and ± 0.01 %
linearity provide a quality link from the sensor to the
controller input.
how do I interpret this? the application note can be found here:
the text is on page page 1.
Hope someone of you can learn me how to use these devices! Thank you for the help!
like these ones:
controller input.
