line follower robot programminh
Parth86
HI,
I have just started to write c code. please suggest me i am going to wrong way
algorithm
If sensor is High -both motor move forward
If sensor is Low- stop both motor
PORT A A0 A1 A2 A3 A4 A5 A6 A7 output of sensor is connected to A4 pin
0 0 0 0 1 0 0 0
PORT B B0 B1 B2 B3 B4 B5 B6 B7 motor1 and motor2 connected pin 2345
0 0 1 1 1 1 0 0
[#include<AVR/IO.h>
main()
while(1)
DDRA=OXOO; //port A as input
DDRB=OXFF; //port B as output
PORTA=0b00001000; // set as high pin
PORTA=0b00000000; //set as low pin
If (port A=00001000); //If sensor is high
(port B=0b00111100); // both motor move forward
If (port A=00000000); //If sensor is Low
(port B=00000000); //stop both motor
If the first "If then" is true that's all it going to do, never see the second one.
I'm not a avr user but I'm sure this is more in line with what your trying to do
#include<AVR/IO.h>
void main() {
DDRA=OXOO; //PORTA as input
DDRB=OXFF; //PORTB as output
PORTB=0b00000000; //let's start with it off
  If (PORTA=0b00001000){ //If sensor is high
      (PORTB=0b00111100); // both motor move forward
    ELSE If (PORTA=0b00000000){ //If sensor is Low
     (PORTB=0b00000000); //stop both motor
  } while(1);
Sure you could or a arduino which uses a AVR but it's easier coding lots of examples. But if you used Mikro C pro AVR to write your code it wouldn't be to hard to write code with it. Great help files with it.
If you used a pic I would go with a 18f14k22 there cheap and when you get done with this you can do some really neat stuff with that little chip.
MikroC pro for the pic is easy to get started with.
I'll post you the same code for the pic.
This is a little better code maybe give you a idea
#define sensor1 PORTA.F0
#define sensor2 PORTA.F1
#define sensor3 PORTA.F2
#define motor_R PORTC.F0
#define motor_L PORTC.F1
#define motor_forward PORTC
#define motor_stop PORTC
void main() {
motor_stop =0b00000000;
     do {
           if (sensor2 == 1){           //starts you rolling forward
              motor_forward = 0x3;
           if (sensor1 == 1){             //stears to right
               do {
                    motor_L =~ motor_L;
                       Delay_us  (100);
               } while (sensor2 == 0);
              motor_forward = 0x3;        // if the center found go forward
             if (sensor3 == 1){          // stears to left
               do {
                    motor_R =~ motor_R;
                       Delay_us  (100);
     }while (1);    // keep doing it
