As a project for better understanding of load control & the need for something out of the ordinary I have built a small dynomometer made up of a 12v DC motor, the load is a small Eddy Current brake that I built.
It is controlled using a PID controller using an Arduino board that I programmed, the small setup is working better than expected & I have full load control & can ramp up & down etc as well as static load testing among some other very nice things.
I am using a LM2917N for frequency to voltage conversion from a tacho optical pickup as one of the inputs to the Arduino.
With this LM2917 I have it configured to have an output of 5v at 200Hz which is the maximum I want for this setup.
What I can't work out is how to limit the output to 5v so it doesn't exceed this value incase of a runaway situation where I will get a higher voltage output that may damage the Arduino input.
I thought I would just use a 5.1v Zener on the output but it doesn't work as expected, maybe I am doing it the wrong way?
I have included the LTSPICE file of the LM2917 circuit that I am using, could someone give me some advice on this, it would be appreciated.
Cheers
Cheers
