Light indicator for e-machine (power push- button)
rogimor
button
Hi, this is my first time here so I am hoping this post is in the right place.
I would like to know where can I purchase a new light indicator(green) for the push button for an e-machine T3302 desktop tower?
regards
rogimor
button
regards
rogimor
I have one that look like this:
It is similar
Thanks for the reply,
It look similar, exept for the snap-in connector. My light indicator uses the LED itself as snap-in connector.
My LED just plugs into the white connector, the pin spacing is about 3mm. will that work? Are you sure the LED is bad? If so, then I will be glad to mail it to you.
Hi
I am sure the LED is good , but the two wires broke right from the LED terminals. I tried to reconnect them by pushing them into the tiny openings, but the wires won’t go in because the residual copper is on the way. It is more like trying to change the filament in a regular light bulb.
Yes , about 3mm is the space for the LED here too. I am sure that the LED you have will fit just fine, but what I don’t know is how the other end of the wires look like. For the part I need the wires must be about a foot long (about 22 AWG) and the end connector to the motherboard must be a female connector. I try to draw it for you.
regards
rogimor
regards
rogimor
The wire on the LED assembly that I sent you a picture of, is 18" long with no connector on the other end. But I also have a motherboard connector like the one you drew a picture of with 3" of wire on it.
