Lift CPU board
2PAC Mafia
I have to repair some CPU lift boards. I have tested all the simple digital IC´s and passive components and all are OK. Measuring consumption and touching (heat) some other complex IC´s I thing I have problems. I would like to replace all of them to be sure I´m solving the problem but my question is about these IC´s. They are:
8255A (Programmable Peripheral Interface)
8254 (Programmable Interval Timer)
8085AH-2 (Single chip 8 bit N channel microprocessor)
8259A (Programmable Interrupt Controller)
Apart of these I have 2 EEPROM 27256 and 2 static RAM. Could I replace these list of components? are they programmed through the software stored at EEPROMs?
The 8255 chips are prone to have individual output pins go bad.
They will be EPROM (not EEPROM), it's very likely that the 27256's contain the entirely programming for the microprocessor, so couldn't be replaced (unless you could source ones ready programmed by the original manufacturer of the board).
However, you don't repair items by testing components, you need to test the entire design as a whole and fault find from there.
What I want to replace are not the EPROM, are these components (in case that are programmed by the EPROM):
I only have this board, I don´t have the complete system so my only way to repair it is testing components in this case. I can´t get the lift with me in my workshop... :)
We know the problem is at this board by replacing it.
Even without the lift, you should be able to do a considerable amount of testing on it - obviously first thing though, the actual 'fault' should give you a major clue to the problem.
You don't mention anything about the symptoms?, but assuming it's dead? then common causes are PSU issues, clock issues, and reset issues - IC failures in uP systems are pretty uncommon.
Hi 2PakMafia,
Yes, you can replace all the the chips. None of them store any information, including code.
spec
Hi 2PakMafia,
spec
Thanks a lot, this was my question because as I said the rest of things I already tested.
No power supply dedicated circuit, 5v coming in from another board.
No probs 2PAK Mafia,
The 8085 brings back memories of the heady days of pioneering personal computers.
And Palma brings back memories of many enjoyable holidays in Majorca.:cool:
The last time I was in Palma, my wife and I took the railway to the north.:happy:
spec
Good, so you know our special and beauty island!!! Best regards.
You could measure the current draw of the circuit and then using the datasheets estimate what it should be, if something is overheating draw is probably excessive.
You could do this on the bench.
Yes, I was thinking about that too but even like this it makes me doubt about if they are 100% so I will replace them.
My IC tester can test some of them but it needs a special adapter which I don't have.
When the lift technicians test the boards they have to go to hotels because this system is very old, I think it's already obsolete from Orona, so I prefer to avoid doubts and have a high % they are repaired.
There is a lift not far from here if it hasnt been replaced yet that uses mercury arc rectifiers like my avatar.
Another possible failure source is age. Programmed parts don't have infinite memories. It varies by different technologies and processes, but your EPROM might only have a lifetime endurance spec of 10 or 20 years. Based on the vintage of the processor used, your assembly is probably at least 30 years old.
So it may be that the data in the EPROM has just become corrupted. Even a one bit change can cause a problem in what it's supposed to do, or cause a CRC check to fail so the processor abort operation.
Another test you can make is to check that the supply voltages on all the chips are correct (meaure directly on the chip pins, 0V and Vcc).
spec
They supplied me the board without EPROM because they used the EPROM at spare working board.
spec
OK, thanks.
