MrMikey83
I have a bank of tri color LED's that I need to be able to use 4 outputs from an ATMEGA32 on. Actually, 3 outputs will go to the possitive side of the LEDs turning on one of three transistors to choose the color of the bank. Then, an output to each LED to light them individually.
My question is do I need to have a transistor on the negative side or can I feed each LED's negative to an output on the Microcontroller so it is on when there is a 0 on the output pins?
~Mike
~Mike
