LED(s) as Strobe Light
adamey
I need a circuit that can drive an LED at a higher than usual output for a very brief period of time so as to act like a strobe.
I also need a triggering circuit that will flash the LED on the trailing edge of a 5V digital signal (pulse train with a low duty cycle of about 10%).
Can Luxeon LED's be driven at very short pulse widths?
Use a multi-vibrator that generates a short pulse, and turn the LED voltage up past the normal spec. If you're lucky, it'll run for a few seconds before burning out.
leds can be driven really fast, since they're nothing more than a semiconductor junction. the issue is, they're not any brighter flashing as they are solid on. driven at 1khz, the various luxeon parts are rated for only slightly higher currents than their constant state rating. lumileds and SSC both make leds rated for a very high pulse current but a very low constant current - specifically designed as mobile phone photo-flash sources.
there's no way you'll be able to outshine an arc discharge strobe with an led, even the tiny xenon tube in a disposable camera consumes more power than a large led array during its discharge.
I'm pretty cure a Luxeon LED can be driven at very narrow% duty cycle (i.e. pulsed > 10 A, maybe could get get 30 A through it?). If the average amps is kept below 100 mA then a heat sink won't be needed.
I've been thinking about the idea of using a triangle waveform to the LED and see if it gives the flashing effect. I talked about that in another threat. What do you think?
You just need a pulse train to get the flashing effect, not a triangular wave.
Do you know what exactly would i get with a trangular wave?
At low enough frequencies, a triangle wave will cause the LED(s) to get gradually brighter and dimmer.
To get a strobe effect, you need pulses with a narrow pulse width (duty cycle).
thanks for the answer, if the frequency would be high(I make it high), wouldn't it make that effect but continuous? i mean the same effect than with the pulses.
In the other hand, I would get a strobe light with a simple astable multivibrator output, i'm i wrong?
Kind of.
A proper stobe light has very fast pulses (very low duty cycle). A regular astable has a 50% duty cycle - an equal on and off time.
Richard
Mulitvibrators can be made to any produce any duty cycle. For a prope strobe light however, you need a circuit with a gas discharge device, ie a xenon tube.
Well yes, but i'm looking for a cheaper circuit that gives me the most similar effect, trying to design it.
There is no similar effect ... the output of the xenon tube is HUGE compared to anything an LED could generate. You need a lot of expensive leds to replicate that effect. You'll see this in police cars ... departments that have a lot of money but are low on brains buy LED light bars for their cars because they're sold on the long service life and the "wow" factor of something high tech. Older, established and cash strapped departments however still chose xenon strobe lights because they're inexpensive and very bright compared to the leds. The leds might have a higher apparent brightness because their pulse width is wider than that of the xenon tube. Apparent brightness only matters when you're looking directly at something... The short duration but immense power of a xenon strobe affects your peripheral vision, so you notice it even if looking in a different direction.
I'll try something, and posts results.
