LED light circuit problem.
Shyamal
I am using a simple circuit to light my room. Here i use 20 LED. After few days later my LED is damaged simultaneously. For this reason i need to change it again and again.
Now what cai i do for this circuit?
In my circuit i use 3 Volt power supply.
I not use voltage regulator ic.
There are many, many ways to wire LED's. Do you have a schematic for how you connected them, and what kind of LED's they are?
What is the amperage rating of the power supply?
-Hans
Obviously too simple! You must control the current through the LEDs. That would normally require at least a series resistor per LED (or per LED chain). A 3V supply allows no 'headroom' for current control. A higher supply voltage is advisable.
We need to know more information.
LED current? 20mA, 100mA, 1A
LED voltage? 1.5V, 3V (never drive a 3V LED at 3V)
I don't see we can help. We do not know if he is using "3V leds". If he is lighting a room then he might be using 3watt LEDs. OR Maybe he is using 20mA LEDs. Picking a resistor with out knowing voltage or current seems a wast of time.
