LCD showes nothing
manba
Hi, everybody
I'm using PIC Tutorial Three - LCD Modules of Nigel Goodwin tutorial to control LCD.
I have wrote the code in MPLAB V7.5
;LCD text demo - 4 bit mode
;Nigel Goodwin 2002
	LIST	p=16F628		;tell assembler what chip we are using
	include "P16F628.inc"	;nclude the defaults for the chip
	ERRORLEVEL	0,	-302	;suppress bank selection messages
	__config 0x3D18			;sets the configuration settings (oscillator type etc.)
		cblock	0x20			;start of general purpose registers
			count			;used in looping routines
			count1			;used in delay routine
			counta			;used in delay routine
			countb			;used in delay routine
			tmp1			;temporary storage
			tmp2
			templcd			;temp store for 4 bit mode
			templcd2
		endc
LCD_PORT	Equ	PORTA
LCD_TRIS	Equ	TRISA
LCD_RS		Equ	0x04			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
		org	0x0000
		GOTO START
		org	0x0005
		GOTO START
START
		movlw	0x07
		movwf	CMCON			;turn comparators off (make it like a 16F84)
Initialise	clrf	count
		clrf	PORTA
		clrf	PORTB
SetPorts	bsf 	STATUS,		RP0	;select bank 1
		movlw	0x00			;make all pins outputs
		movwf	LCD_TRIS
		bcf 	STATUS,		RP0	;select bank 0
		call	Delay100		;wait for LCD to settle
		call	LCD_Init		;setup LCD
		clrf	count			;set counter register to zero
Message		movf	count, w		;put counter value in W
		call	Text			;get a character from the text table
		xorlw	0x00			;is it a zero?
		btfsc	STATUS, Z
		goto	NextMessage
		call	LCD_Char
		call	Delay255
		incf	count, f
		goto	Message
NextMessage	call	LCD_Line2		;move to 2nd row, first column
Message2	movf	count, w		;put counter value in W
		call	Text2			;get a character from the text table
		btfsc	STATUS, Z
		goto	EndMessage
		call	LCD_Char
		incf	count, f
		goto	Message2
EndMessage
Stop		goto	Stop			;endless loop
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init	movlw	0x20			;Set 4 bit mode
		call	LCD_Cmd
		movlw	0x28			;Set display shift
		call	LCD_Cmd
		movlw	0x06			;Set display character mode
		call	LCD_Cmd
		movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		call	LCD_Clr			;clear display
		retlw	0x00
; command set routine
LCD_Cmd		movwf	templcd
		swapf	templcd,	w	;send upper nibble
		andlw	0x0f			;clear upper 4 bits of W
		movwf	LCD_PORT
		bcf	LCD_PORT, LCD_RS	;RS line to 0
		call	Pulse_e			;Pulse the E line high
		movf	templcd,	w	;send lower nibble
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_CharD	addlw	0x30
LCD_Char	movwf	templcd
		movwf	LCD_PORT
		bsf	LCD_PORT, LCD_RS	;RS line to 1
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_Line1	movlw	0x80			;move to 1st row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line2	movlw	0xc0			;move to 2nd row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line1W	addlw	0x80			;move to 1st row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_Line2W	addlw	0xc0			;move to 2nd row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_CurOn	movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_CurOff	movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_Clr		movlw	0x01			;Clear display
		call	LCD_Cmd
		retlw	0x00
LCD_HEX		movwf	tmp1
		swapf	tmp1,	w
		andlw	0x0f
		call	HEX_Table
		call	LCD_Char
		movf	tmp1, w
		andlw	0x0f
		call	HEX_Table
		call	LCD_Char
		retlw	0x00
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (4 MHz clock)
d0		movwf	count1
d1		movlw	0xC7			;delay 1mS
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
Pulse_e
		bsf	LCD_PORT, LCD_E
		CALL Delay5
		bcf	LCD_PORT, LCD_E
		CALL Delay5
		retlw	0x00
;end of LCD routines
HEX_Table  	ADDWF   PCL       , f
            	RETLW   0x30
            	RETLW   0x31
            	RETLW   0x32
            	RETLW   0x33
            	RETLW   0x34
            	RETLW   0x35
            	RETLW   0x36
            	RETLW   0x37
            	RETLW   0x38
            	RETLW   0x39
            	RETLW   0x41
            	RETLW   0x42
            	RETLW   0x43
            	RETLW   0x44
            	RETLW   0x45
            	RETLW   0x46
Text		addwf	PCL, f
		retlw	'H'
		retlw	'e'
		retlw	'l'
		retlw	'l'
		retlw	'o'
		retlw	0x00
Text2		ADDWF   PCL, f
            	RETLW   'R'
            	RETLW   'e'
            	RETLW   'a'
            	RETLW   'd'
            	RETLW   'y'
            	RETLW   '.'
            	RETLW   '.'
            	RETLW   '.'
            	RETLW   0x00
		end
Then simulat the program using PROTUSE. However the LCD shows nothing.
Please help me :confused:
Why not build it?, simulators aren't real life - my LCD tutorials are tried and tested, and work without problems.
ok, I'm going to build it. However I dont have pic16f628, I have pic16f877a. So, I'm going to make some changes.
thank you in advance { Nigel }
Hi Nigel,
For reference only, Tut#3 works fine in Oshonsoft, as do all your others that I have tried for OP's.
Hi Nigel,
hi, { ericgibbs }
I traid to simulat the circuit in Oshonsoft. However nothing shows in the LCD.
hi, { ericgibbs }
Did you set up the Oshonsoft LCD module.??
Run at Ultimate Rate and wait until the Program delays time out. takes about 5 to 10 seconds.
