lcd menu
This code wont work:
  //--- main loop
  do {
    if(Button(&PORTA,2, 1, 0)) {
             MainMenu();
    else {
            read_temp();
    } while (1);
Change it to :
  //--- main loop
  do {
    if(KeyPORT == ENTER) {
             MainMenu();
    else {
            read_temp();
    } while (1);
I say it wont work because its always high since pulled high so you have to check for low. Did you change the definition to:
#define KeyPORT (~((PORTA>>2)&0x0F))
This is how I would normally turn an led on via a switch.
When first turned on "Waiting" is displayed when switch 1(RA2) is pressed "LED ON" is displayed and the LED is turned on, when switch 2 (RA3) is pressed "LED OFF" is displayed and the LED is turned off.
This is all the code I am using, any other include files must be automatically selected by mikroc and I cannot see what it is.
// LCD connections definitions
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD connections definitions
void main() {
  CMCON  |= 7;                       // Disable Comparators
  Lcd_Init();                        // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);               // Clear LCD
  Lcd_Cmd(_LCD_CURSOR_OFF);          // Turn cursor off
  Lcd_Out(1, 3, "Waiting");
  do {
  if (Button(&PORTA, 2, 1, 0)) {  // Detect logical one to zero
     Delay_ms(100);
     Lcd_Out(1,1, "LED ON");
     TRISA.F6 = 0;
     PORTA.F6 = 1;
  if (Button(&PORTA, 3, 1, 0)) {  // Detect logical one to zero
     Delay_ms(100);
     Lcd_Out(1,1, "LED OFF");
     TRISA.F6 = 0;
     PORTA.F6 = 0;
  } while (1);
here is teh equavalent code but written the way you have shown me, but it does not recognise switch presses:
#define KeyPORT ((PORTA>>2)&0x0F)
#define ON   2
#define OFF  3
unsigned char WaitForInput(void){
	unsigned char temp1;	//TEMP DATA HOLDER
	unsigned char done = 0; //DONE Var will determine if done
	while(!done){				  //while done == 0
		if(KeyPORT>0){			  //if KeyPORT aka PORTB&0x0F.. the &0x0f will make sure we
						  //return the lower part of port only RB0 to RB3
			temp1 = KeyPORT;	  //Place the lower part of port into temp variable
			while(KeyPORT==temp1);    //Like a debounce for button press
			done = 0xFF;		  //Set DONE Var so we know we are complete
	return temp1;				  //Return our temp1 var
void main() {
  do {
  //--- main loop
   switch(WaitForInput()){
		case ON:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 1;
			break;
		case OFF:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 0;
			break;
	} while (1);
oops forgot about the define, now change to
in my example script aswell but wit the same result
Im downloading MikroC now to try it out but try this for now:
#define ON   1
#define OFF  2
s
void main() {
  TRISA = (0x0F<<2);                 // [b]RA5,RA4,RA3,RA2 are set to input[/b]
  do {
  //--- main loop
		case ON:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 1;
			break;
		case OFF:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 0;
			break;
	} while (1);
Ok thanks I gess you use a different compiler? Your suggestion did the same as what my code did, just displays waiting.
This works nice:
#define ON   2
#define OFF  3
    unsigned char done = 0;           //DONE Var will determine if done and hold key
      if (Button(&PORTA, ON, 1, 0))   //Is On button pressed (LOW)
          done = ON;                  //If So set done to ON
      if (Button(&PORTA, OFF, 1, 0))  //Is Off button pressed (LOW)
          done = OFF;                 //If so set done to OFF
    return done;		      //Return our done/key var
void main() {
  do {
  //--- main loop
		case ON:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 1;
			break;
		case OFF:
                     Delay_ms(100);
                     TRISA.F6 = 0;
                     PORTA.F6 = 0;
			break;
	} while (1);
This also works well:
          return ON;                  //If So set done to ON
          return OFF;                 //If so set done to OFF
I thought I would add the array to the script and thought that the following should still loop through the menu:
#define MENU   2
#define UP  3
#define DOWN  4
 unsigned char MainMenuLIST[3][16] = {
{"Option 1"},
{"Option 2"},
{"Option 3"}
    if (Button(&PORTA, MENU, 1, 0))
          done = MENU;
    if (Button(&PORTA, UP, 1, 0))
          done = UP;
    if (Button(&PORTA, DOWN, 1, 0))
          done = DOWN;
void main() {
  unsigned char POS = 0;
  unsigned char x;
  TRISA = (0x0F<<2);                 // RA5,RA4,RA3,RA2 are set to input
  do {
  //--- main loop
		case MENU:
                     Delay_ms(100);
                     for(x=0;x<2;x++){
                       if(x == POS)
                       Lcd_Out((x+1),2,">");
                     else
			Lcd_Out((x+1),2," ");
                     Lcd_Out((x+1),2,MainMenuLIST[x]);
                     break;
                case UP:
                     if(POS>0){
               	     POS--;
                     break;
		case DOWN:
		     if(POS<1){
		     POS++;
		break;
	} while (1);
This scrip displays "Waiting" when MENU is pressed it displays "Option 1" on line 1 and "Option 2" on line 2 however there is no "<" on the screen and pressing UP and DOWN do nothing and I never see option 3.
I would of expected this to:
Waiting
Press MENU
>Option 1
Option 2
press DOWN
>Option 2
Option 3
press DOWN
Option 2
>Option 3
I have just changed
for(x=0;x<2;x++){
                       if(x == POS)
                     else
to
for(x=0;x<2;x++){
                       if(x == POS)
                       Lcd_Out((x+1),1,">");
                     else
			Lcd_Out((x+1),1," ");
and it now displays:
>Option 1
Option 2
however the UP and DOWN switches still do nothing
The following works as expected but only for options 1 and 2, option 3 is still never shown:
#define MENU   2
#define UP  3
#define DOWN  4
{"Option 1"},
{"Option 2"},
{"Option 3"}
          done = MENU;
          done = UP;
          done = DOWN;
void MainMenu(void){
unsigned char POS = 0; 	//Used for cursor ONLY!
unsigned char x;
unsigned char ITEM=0;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			break;
		case MENU:
			done = 0xFF;
			break;
	// ITEM contains what item is selected
	// POS isnt used incase larger then 2 menu...
	switch(ITEM){
		case 0:
                Lcd_Out(1, 3, "temp   ");
                Delay_ms(2000);
			break;
		case 1:
                Lcd_Out(1, 3, "Time");
                Delay_ms(2000);
			break;
	//Bring our title back.. cuz we are done with the menu...
void main() {
  unsigned char x;
      do {
		case MENU:
		Delay_ms(100);
		MainMenu();
		break;
} while (1);
look at my other menu... you need a starting point aka a page reference... check this post in 1 minute for code below
EDIT: TRY THIS:
unsigned char x;
unsigned char PAGE=0;
while(!done){
	for(x=0;x<2;x++){
		if(x == POS)
		else
        Lcd_Out((x+1),2,MainMenuLIST[(x+PAGE)]);
		case UP:
			if(POS>0){
				POS--;
				ITEM--;
			} else {
        if(PAGE != 0) PAGE--;
			break;
		case DOWN:
			if(POS<1){
				POS++;
				ITEM++;
			} else {
        PAGE++;
			break;
		case MENU:
			done = 0xFF;
			break;
[B]  ITEM+=PAGE;[/B]
	switch(ITEM){
		case 0:
                Delay_ms(2000);
			break;
		case 1:
                Delay_ms(2000);
			break;
Try it now heh i forgot to add the 1 line:
ITEM+=PAGE;
