LCD Bargraph code?
augustinetez
Most Helpful Member
On the off chance, does anybody have some simple code already written that will take a 0-5V voltage applied to the ADC input and convert it to a bargraph on a 16x2 or 20x4 LCD?
For the 16F1827 PIC.
I found one written for Proton Basic but their free trial compiler seems to be no longer available and of course it won't work in the Oshonsoft compiler without a total rewrite.
I've only got the Oshonsoft compiler at the moment and it's been way too long since doing any Basic programming.
4 bit PortB and ADC on Port A, doesn't matter which pin.
Thanks Ian.
Ian, can you define the first eight (or 5) characters to be 1 to 5 pixels (if memory serves well) so you can have a 1 pixel bar?
Yeah! I do that, but it looks rubbish This is the way Proton Basic do it and it actually looks better..
The characters are 1 space away from each other..
I have two types ( now three ) one is a 16 character box and the position moves from one side to the other.. Like a slider..
I made it "muck about-able" Any size, up to 20 chars 3 or 5 bar resolution It now accepts 0 ~ 100%
Enjoy... I do like the 3 line type.. But now its up to you.. I enjoyed doing this..
  • bar.bas
Sometimes.. On a Sunday when all else is a sleep.. I can write pages of code ( mostly C ) and surprise myself that no syntax or compile errors have occurred.. It bowls me over sometimes..
Because I have a full copy of Proteus.. I can test immediately..
I'd be more than surprised :D
Always a curly bracket missing, or confusion with '=' and '==' :D
For reasons I haven't worked out yet, the first Bar graph file refused to work on the '1827 test bed so I ported it across to my 16F886 test bed.
Likewise it also refused to co-operate.
Just to make sure I hadn't completely lost the plot I ran the 'Hello world' script in the same file (commenting out all the bar graph code) which ran fine, which is when I noticed the 'All_Digital' command and applied it to the bar graph code - success. Still to try it on the '1827.
My amended code below:
C:
'For 16F886 4MHz clock and using R/W bit in LCD interface
Define CONFIG = 0x20c4
Define CONFIG2 = 0x3fff
#define LCD_LINES = 4
#define LCD_CHARS = 20
#define LCD_BITS = 4
#define LCD_DREG = PORTB
#define LCD_DBIT = 0
#define LCD_RSREG = PORTB
#define LCD_RSBIT = 6
#define LCD_EREG = PORTB
#define LCD_EBIT = 4
#define LCD_RWREG = PORTB
#define LCD_RWBIT = 5
#define LCD_COMMANDUS = 5000  'delay after LCDCMDOUT, default value is 5000
#define LCD_DATAUS = 100  'delay after LCDOUT, default value is 100
#define LCD_INITMS = 100  'delay used by LCDINIT, default value is 100
'the last three Define directives set the values suitable for simulation; they should be omitted for a real device
#define ADC_Clk = 3
#define ADC_Sample_uS = 50
All_Digital
TRISB = 0
ANSEL = %00000100  'configure all PORTA pins except RA2 as digital I/O's
Dim buffer(16) As Byte
Dim data As Word
Dim dumm As Word
Lcdinit 0
Lcddefchar 0, %00000, %00000, %00000, %00000, %00000, %00000, %00000, %00000
Lcddefchar 1, %10000, %10000, %10000, %10000, %10000, %10000, %10000, %10000
Lcddefchar 2, %10100, %10100, %10100, %10100, %10100, %10100, %10100, %10100
Lcddefchar 3, %10101, %10101, %10101, %10101, %10101, %10101, %10101, %10101
main:
    ADC_Read 2, data
    dumm = data / 21
    dumm = dumm * 100 / 48
    Lcdcmdout LcdLine1Home
    Lcdout " BAR GRAPH ", #dumm, " "
    Lcdcmdout LcdLine2Home
    Call bar(data)
Goto main
End
Proc bar(dat As Word)
    Dim idx As Byte
    Dim pos1 As Byte
    Dim pos2 As Byte
    pos1 = dat / 21
    pos2 = (pos1 Mod 3)
    pos1 = pos1 / 3
    For idx = 0 To 15
        buffer(idx) = 0x20
    Next idx
    For idx = 1 To pos1
        buffer(idx - 1) = 3
    Next idx
    If pos2 = 0 Then
        buffer(idx - 1) = 0x20
    Else
        buffer(idx - 1) = pos2
    Endif
    For idx = 0 To 15
        Lcdout buffer(idx)
    Next idx
End Proc
'All_Digital
'Lcdinit LcdCurBlink
'loop:
'Lcdout "Hello world!"
'WaitMs 1000
'Lcdcmdout LcdClear
'WaitMs 1000
'Goto loop
I think it was just for porting over to the 16F886 - it has ANSEL and ANSELH - I forgot about the last one, will change it tomorrow and drop out the 'All_digital' to see what happens.
Swapped out 'All_digital' for the added 'ANSELH = 0' in the 16F886 code and it worked, will have another go with the 16F1827 version a little later.
Also just a quick note on a bug in the Oshonsoft Basic Compiler versions when using the sim with an LCD (confirmed by Vlad after I sent the report).
When you load the sim which is using the LCD module, it asks if you want to use the connection/port details from the loaded program - this works fine if you use this form of 'Define xxxx'.
However, if you use '#define xxx', it doesn't work and you have to manually configure the LCD module every time.
The '#' is an escape character primarily for C for the pre-processor... Basic doesn't use them..
If you look at ALL his examples they are not used... BUT!! I would have thought an error would occur
Also the #define IS the line in the help file.. I think the help file is cocked up..
