LC filter in a design, why not an RC filter?
This is what LTS shows.
Simulating a short pulse on the the paralleled pins of 3V, the Vout [analog] rings at approx 2Khz.
The 47K simulates the loading across the 100nF.
E
Rings a bit doesn't it :D
Can you do the same for the current? (directly from the source of course).
Showing current at MCU pins [V1]
Sorry about delay in replying, working on a PCB artwork.;)
E
EDIT: Added MCU internal clamp diodes, 2nd image
So what about current if you replace the choke with a resistor? - it's good this remote control simulation :p
I think what designer may have in mind is to use the inductor to reduce the inrush current drawn from the MCU pins that are charging the 100nF, when the pins are set low to high.
Also it will minimise the voltage loss across the inductor, if its resistance is low.
I have increased the load current to approx 1mA.
Without the inductor or resistor connected between the MCU and 100nF, the MCU pins are required to try to output a 300mA current spike.
I have added some source resistance to the MCU pins to limit the s/c current to 25mA/pin for the sim.
Interestingly this is the MCU pin current spike with the 47uH inductor and the MCU source set to only 1R, its well within the MCU specification.
NOTE: the inductor self resistance is set as zero ohms
E
That was Mr RB's thought - and the simulation seems to show that even a 47uH with only a 0.1uF does reduce the surge.
As to whether it makes any practical difference though is a different matter :D
But it's probably cleared up the reasoning behind it.
But it does take 3ms to stabilize.
The LTS sim suggests about 3mSec, I expect the programmer allowed a longer time before he started using the analog section of his project.
Hello again,
Well, there is more than one way to set the output drive logic for most uC chips. So far we only assumed it was providing a drive pulse of zero to plus supply voltage. But the pin can easily provide a high impedance to plus supply voltage pulse. That would make the 'off' time look like a high impedance rather than a pull down to zero volts.
With a high impedance during the pulse 'off' time and the plus supply voltage during the pulse 'on' time, we would see a more conventional output that looks more like a PWM modulated DC voltage. That's not to say that is really what they are doing here, but that is what we would see should we drive it that way instead.
This could be simulated to some degree with a diode between the pulse source and the inductor capacitor circuit.
I wonder why not to use a mosfet to switch analog on and off. This makes for more robust system with less parts.
Inductor, capacitor, two resistors and 3 pins
or
Mosfet and 1 pin.
It must be something else that made them go the distance.
The pin's clamping diode does make it into a full buck SMPS configuration, so switching the pins on and off is capable of producing less voltage. Is it a 5V MCU? Making 3V for analogs? Or less? It is a battery application and they seem to be paranoid about saving power.
or
Mosfet and 1 pin.
Using a mosfet will still produce an identical surge, so would still require the choke - assuming that's what it's there for, and that it's actually having any effect.
A project I'm involved in does use a mosfet to switch the power, actually to a GSM modem chip, so there's a very substantial surge there - yet no need for a choke.
hi Al,
Using a switch thats closed or open to simulate a MCU pin set High and Tristate , this what I see.
If you think about it the Vo on the 100nF cannot go higher than 3V+ diode clamp voltage.
I am assuming like most MCU's the pins are internally clamped.
E.
BTW: I have tried a range of switching frequencies
Yes, but the mosfet will take power from the rail, so the surge will not affect the pin(s).
Microchip in their data sheets for PIC24H (that's what I use) suggest using a choke for analog power. I tried and I didn't see any difference.
I think the diodes should be connected to the point labelled mcu1, rather than Vo.
I would also put the voltmeter to Vo instead of mcu1 because that's what the analog devices will see.
I think the idea was to prevent surges from the battery, which was tiny - no problem for such a tiny surge via the pins, which will self limit it anyway.
Interesting about the 24H - perhaps the AVR datasheet suggested the same thing, which is the sole reason it's there :D
The diodes should be the other side of the inductor, but the difference in Vo is not discern able.
The voltmeter Plot already shows Vo not the MCU voltage
hi Al,
E.
Hi Eric,
Yes that looks much better now. But im still a little puzzled by the very low value capacitor of 100nf. That tells me that they wanted to be able to change the DC level very quickly. But it's almost too fast, and the values shown would probably require a switching frequency of 100kHz or something. That's a lot of housekeeping for the uC i think unless this analog output is a very important feature. Unless maybe they use another cap as part of the load.
But at least we are now seeing PWM, and the internal diode to ground means it's a real buck circuit.
BTW where did that 3k resistor come from? Is that the load now?
